icon keyboard
Under bookworm, the keyboard icon appears at the bottom right of the screen when you activate an application with which you can use it, but under trixie the keyboard icon doesn't appear.
What configuration needs to be activated for the keyboard icon to appear at the bottom right of the screen?
Thanks,
@+ Chris
There is no configuration. This is Phosh, it follows the GNOME design philosophy, which basically says no options, ever.
As I understand it, you are supposed to hold the finger on the bottom bar for a while until the keyboard pops up. Do not ask me who thought such an undiscoverable feature was good design.
(What they did in Phosh 0.36.0 is that they added an option… allowing you to configure for how long you have to hold the finger until the keyboard pops up! No kidding.)
(02-07-2024, 09:35 PM)Kevin Kofler Wrote: There is no configuration. This is Phosh, it follows the GNOME design philosophy, which basically says no options, ever.
it works!
Tanks Kevin
It worked for me too! That's great, but yeah, how on earth is anyone supposed to know this intuitively?
Ah, Gnome. The devs should get out more and see how their great ideas work for people with a fine motor co-ordination deficit. Touch screens generally give me a lot of grief. I must get on with sorting out a script to let me rotate the XFCE desktop and touch screen as XFCE works much better for me than Phosh (or any other "touch screen optimised" GUI that I have used so far).
I have sort of discovered this feature to get the on screen keyboard up except it does not seem to work consistently on my PinePhone. Neither does hitting the minuscule keyboard icon on the bottom right of the screen. At 100% screen magnification it is very hard to see and even harder to hit.
However, I think that part of the problem is that unlike a feature phone where the OS prioritises urgent tasks over non-urgent the delay/non-appearance of the on screen keyboard seems to be also related to how busy the PinePhone is with other tasks. Such as finishing loading the rest of the webpage. Or loading something in the background.
Is there any way to map the volume controls buttons pressing "volume up - volume down" in quick succession to a script so that that the keys can be used to bring up/hide the on screen keyboard?
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,333 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,723 12-23-2025, 04:25 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,576 01-15-2025, 08:08 PM
  New keyboard issue sandspur 30 40,801 01-13-2025, 01:37 AM
  Keyboard not popping up on QT apps 3x5co 1 3,421 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 3,115 10-29-2023, 08:34 AM
Last Post: walter1950
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,259 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,765 12-22-2022, 07:10 PM
Last Post: acid andy
  The settings icon disappeared kubussz 34 41,022 11-15-2022, 10:56 AM
  Would creating a 2 row landscape keyboard be difficult? rp3 1 3,472 09-09-2022, 06:49 AM
Last Post: zetabeta
