bookworm vs trixie discussion for mobian in pinephone pro.
(02-20-2024, 12:40 PM)mburns Wrote:
(11-18-2023, 07:58 AM)mburns Wrote: The Camera and Megapixel apps in Trixie are not working. So, I copied the Megapixel files and my customizations from an older installation of Mobian.
The Tootle app is no longer in the repositories, so I copied the files from an older installation and then did a schema compile to get the app working. The desktop file needs a complete pointer to the location of the icon.
A capabilities problem with the Bubblewrap package prevents the Web app from starting. There is also an incompatibility of Mobian setup with Google Accounts that can prevent the Web app from starting. The app can be started from the command line, though; epiphany-browser is the executable name.
Someone could comment on getting the PinePhone Keyboard working in Trixie. But a Bluetooth mouse and keyboard work in Trixie.
The Web application is now working in Trixie Mobian, but not with Google approval.
Drivers for the cameras, or their invocation, have been dropped in the most recent update of Trixie Mobian. I am not sure if restoring the specific PinePhone Pro support package will work for this issue.
Support for the camera has been restored in Mobian Trixie as of Tuesday, April 23. But only the older version of megapixels that I saved works.
On Thursday, April 25, there is a dangerous dist-upgrade available for Mobian Trixie. Don't do it!
(04-25-2024, 12:24 PM)mburns Wrote: On Thursday, April 25, there is a dangerous dist-upgrade available for Mobian Trixie. Don't do it!
it seems that it is related to t64 transition, and it is a mess.
https://micronews.debian.org/2024/1709031141.html
i updated mobian on pinephone regular, and it seems that t64 packages has started to roll down into testing/trixie. well, trixie is more or less unstable anyway, but this is more complicated mess. i don't have any good advises beyond manually selecting t64 packages.
i already have experience of this mess, because i updated unstable debian somewhat recently on one of my x86-64 machines.
The 64-bit time_t transition should be entirely irrelevant for 64-bit platforms such as aarch64, time_t has always been 64-bit on 64-bit platforms.
(04-26-2024, 03:44 AM)Kevin Kofler Wrote: The 64-bit time_t transition should be entirely irrelevant for 64-bit platforms such as aarch64, time_t has always been 64-bit on 64-bit platforms.
It would be unwise to underestimate the impact on ANY platform, including all 64-bit platforms.
This is likely the biggest transition I've seen in my ~15 years of using Debian.
Do NOT underestimate its impact.
Some tips:
  • Do NOT use full-/dist-upgrade. People should generally not use it, but that's especially true now
  • Waiting is a virtue. Forcing things (which is what full-upgrade does) is generally a bad idea. Even more now. All the issues will be fixed/resolved over time.
  • Do NOT use the '-y' parameter to apt and READ all that APT is telling you it's about to do. Responding 'N(o)' has always been a valid response and even more now.
HTH
Then the Debian packaging is really messed up, because the transition is clearly a no-op on 64-bit platforms and should be (but apparently is not) treated as such.
(04-26-2024, 05:40 AM)diederik Wrote: Some tips:
It turns out that with "apt" you actually do need to use dist-upgrade to remove packages so they can be replaced with their time64/t64 successor.
source: the Debian apt maintainer and they should know Wink
That's apparently one of the differences with aptitude, which is what I always use, which just removes packages that are no longer needed or are replaced by another package.
mobian has released trixie, release number is 13.
that practically means that using bookworm is not useful anymore, it is now oldstable.
in the future, choice will be in between forky 14 and trixie 13.
https://blog.mobian.org/posts/2025/10/ne...ting-keys/
Oldstable remains supported with regular updates for a few months, then LTS and then ELTS updates. But of course, running stuff that old on a phone is not all that great because mobile GNU/Linux moves fast.
(10-17-2025, 02:33 AM)zetabeta Wrote: mobian has released trixie, release number is 13.
To clarify do we update /etc/apt/sources and sudo apt dist upgrade as I did from bookworm to trixie?
  Upgrading from Trixie to Forky in late 2025(proposal)(tested works for me) biketool 5 6,116 10-28-2025, 03:31 PM
  Experimental Mobian kernel patch for extended battery life teekay 15 16,661 10-27-2025, 08:43 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 62,246 10-13-2025, 07:46 AM
Last Post: Habbytm
  Bare metal on Pinephone Pro alain 0 3,503 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,681 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,690 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,563 04-18-2025, 12:56 AM
Last Post: teekay
  Debian vs Mobian henrythemouse 3 3,655 04-06-2025, 02:15 AM
Last Post: henrythemouse
  Battery life thread: discussion, support and tips apink 12 15,070 03-01-2025, 10:39 AM
Last Post: d50zesl0g@mozmail.com
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,707 02-26-2025, 02:15 AM
Last Post: TOF
