debugging issue realted to iso image wth extra data eror
Hi all-
I work with the ai.
I ran this line:
dd if=shared.disk-image.img of=shared.disk-image.iso
I get this error:
/c/msys64/mingw64/bin/7z x /c/Users/myuser/Downloads/is02/shared.disk-image.iso
7-Zip 23.01 (x64) : Copyright (c) 1999-2023 Igor Pavlov : 2023-06-20
Scanning the drive for archives:
1 file, 5250048 bytes (5127 KiB)
Extracting archive: C:\Users\myuser\Downloads\is02\shared.disk-image.iso
0.Firmware (Tow-Boot).img
ERRORS:
There are data after the end of archive
Path = C:\Users\myuser\Downloads\is02\shared.disk-image.iso
Type = GPT
Physical Size = 5250048
ID = E0CA6E57-39B2-4482-9838-21E2785CD93D
Path = 0.Firmware (Tow-Boot).img
Size = 4194304
File System = 67401509-72E7-4628-B1AF-EDD128E4316A
Characteristics = Sys
Offset = 8192
ID = CE8F2026-17B1-4B5B-88F3-3E239F8BD3D8
Type = gzip
ERRORS:
Offset = 617544
Physical Size = 3149
Tail Size = 3573611
Headers Size = 10
Streams = 1
ERROR: There are some data after the end of the payload data : 0.Firmware (Tow-Boot)
Sub items Errors: 1
Archives with Errors: 1
Open Errors: 1
Sub items Errors: 1
so the issue was per ai to check and see if the file is corrupted so i with the ai help came up with this:
Quote:python.exe test.py
  File "/c/Users/myuser/Downloads/is02/test.py", line 5
    p = subprocess.Popen(["PYTHONPATH=$PYTHONPATH:/c/msys64/usr/bin", 'python", "/usr/bin/binwalk", "-e", "shared.disk-image.img"], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
SyntaxError: unterminated string literal (detected at line 5)
mycomputer@name MSYS /c/Users/myuser/Downloads/is02
$ python.exe test.py
Traceback (most recent call last):
  File "/c/Users/myuser/Downloads/is02/test.py", line 5, in <module>
    p = subprocess.Popen(["PYTHONPATH=$PYTHONPATH:/c/msys64/usr/bin", "python", "/usr/bin/binwalk", "-e", "shared.disk-image.img"], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
  File "/usr/lib/python3.11/subprocess.py", line 1026, in __init__
    self._execute_child(args, executable, preexec_fn, close_fds,
  File "/usr/lib/python3.11/subprocess.py", line 1953, in _execute_child
    raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'PYTHONPATH=$PYTHONPATH:/c/msys64/usr/bin'
mycomputer@name MSYS /c/Users/stealth_droid/Downloads/is02
Exit code: 0
#!/usr/bin
import subprocess
# Execute the Binwalk command
p = subprocess.Popen([ "python", "/usr/bin/binwalk", "-e", "shared.disk-image.img"], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
# Communicate with the Binwalk command and get the output and error messages
output, error = p.communicate()
# Check the exit code of the Binwalk command
exit_code = p.returncode
# Print the exit code
print("Exit code:", exit_code)
so the issue then becomes 0 error code no error.
the output is a file named:
what other outputs would i expect after unpacking the tow-boot with 7zip?
thanks for any input.
jim
(03-21-2024, 03:28 PM)penguins_rule Wrote: Hi all-
I work with the ai.
I ran this line:
I get this error:
ERRORS:
Type = GPT
Size = 4194304
Offset = 8192
Type = gzip
ERRORS:
Offset = 617544
Tail Size = 3573611
Headers Size = 10
Streams = 1
Sub items Errors: 1
Open Errors: 1
Sub items Errors: 1
Exit code: 0
#!/usr/bin
import subprocess
jim
The output files from tow-boot should include a boot.img file, a recovery.img file, and a vbmeta.img file.
Hi all, I didn't get all 3 of those. So I don't know if this is a side issue.
I can see that it 'possibly' got hung. This recovery.img file is important it is a double cascading failure
notwithstanding I used tow-boot instead of leaving the firmware alone in this case for spi.
thanks for anyone that can fix things at least going forward if i read this right.
jim
thanks,
jim
It was indeed a faulty image and I got a new image that works better.
SORRY!
Quote:zed_pmIt was indeed a faulty image and I got a new image that works better.
https://forum.pine64.org/showthread.php?tid=19153 basketball stars
SORRY!
What is the image you are looking for? can you share? I also have this problem and need a solution
  systemic issue pinephone penguins_rule 3 4,944 04-02-2024, 11:52 AM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 3,038 09-24-2023, 05:18 PM
Last Post: nbh
  new PinePhone upgrade issue WhiteHexagon 5 7,721 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Internal Microphone issue during calls Viktor 6 8,567 03-31-2023, 08:58 AM
Last Post: Viktor
  Firefox issue with latest update Barugon 6 8,273 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  alien desktop image Uturn 2 4,074 11-10-2022, 10:34 AM
Last Post: Uturn
  New issue with phone calls kmsgli 13 18,492 08-15-2022, 01:45 PM
Last Post: Gon
  Call waiting issue kmsgli 22 33,483 06-24-2022, 06:02 PM
Last Post: kmsgli
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 11,938 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  No wifi with phosh image wave22 3 6,092 02-15-2022, 07:25 AM
Last Post: wave22
