Mobian repository status
@biketool Glad you're up and running Smile
(08-10-2021, 09:56 AM)nelstomlinson Wrote: Does Mobian do backports? Or will Mobian Bullseye be not quite frozen? I really want stability and don't want to enable testing if I can avoid it.
As is stands, I believe Mobian relies on some bleeding-edge software from upstream, such as PinePhone-specific firmware. Ergo, there are "third-party" repositories configured to serve those packages.
For ubiquitous userland programs, such as the GNU coreutils, there is no reason why the Mobian developers couldn't use stable. However, this changes when you consider phosh, and other packages developed for the PinePhone and Librem 5.
Mobian could introduce a backports-like system to achieve this, but it isn't available.
I think the Mobian Developers are going to stay on the cutting edge, I believe they are going to jump into 'Bookworm' Debian shortly after the Bullseye release.
"Debian" will continue to support the Mobian mobile branch with security updates.
Check out the Mobian Blog for more details.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Backports would be nice, because that would let me just update a few programs that I actually need to have updated.
Bookworm would be OK for Mobian, except running testing for the whole distro causes a bunch of issues.
Maybe the question I should have asked is: ``What sources lines should I have to keep sort of up to date, without having something important break on every single update?''
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
Hi I'm having problems update pinephone pro with phosh. It says mobian.org could not connect. I have also checked mobian.org and it seems down for the last three days. Any help??
(04-09-2024, 09:44 AM)covar Wrote: Hi I'm having problems update pinephone pro with phosh. It says mobian.org could not connect. I have also checked mobian.org and it seems down for the last three days. Any help??
same here, cannot connect (111:  Connection refused) error doing package update
https://blog.mobian-project.org/ also :-(
Server problems, see https://fosstodon.org/@mobian/112247743295779309
  Mobian MMS/SMS text problem bcnaz 16 37,442 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,469 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,954 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,587 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,215 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,155 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,966 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,670 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,399 04-29-2025, 02:10 PM
Last Post: mdk
