Rock64 No Audio @ Debian 12
How to reproduce:
  • Install Debian 12
  • Observe the "platform analog-sound: deferred probe pending" message in the output of dmesg
Expected: no such message.
The above is the root of the problem, IMHO.
Additionally, you may:
  • Install alsa-utils
  • Observe no analog-sound in the output of alsa -l command, but spdif-sound and hdmi-sound do exist.
Expected: Three sound interfaces: analog-sound, spdif-sound, hdmi-sound (as described in the Device Tree file located in /boot/dtbs/.../rk3328-rock64.dtb).
Linux rock 6.1.0-18-arm64 #1 SMP Debian 6.1.76-1 (2024-02-01) @ Rock64 v2
I can confirm to NOT see an Analog audio card on my Rock64 V2 with Debian 12 (Bookworm), but I also do have SPDIF and HDMI.
IIRC it used to have Analog too, so this seems like a kernel regression.
Via https://snapshot.debian.org/package/linux-signed-arm64/ you can find various older 6.1 kernel versions.
Could you try if the Analog card does appear with an older 6.1 kernel?
Ideally the range between working and not working is as small as possible, so the range for the regression is as small as possible.
@diederik Thank you for the reply. Could you give me a hint about how to try other kernels without fear to loose the system, please? I would try both older and newer versions.
  Rock64 v2.0 u-boot SPI issues ju0n 1 894 09-25-2026, 11:19 PM
Last Post: mysy
  OpenWRT on the Rock64 CanadianBacon 14 28,914 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,020 03-17-2024, 12:22 PM
Last Post: dmitrymyadzelets
  Rock64 won't boot luminosity7 10 19,047 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,935 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,079 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,096 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,475 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,001 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 5,010 10-07-2022, 07:50 PM
Last Post: rookie_267
