Replacement main board for Developers
(11-20-2023, 03:02 AM)mozes Wrote:
(11-17-2023, 12:26 AM)tllim Wrote: You have PM me but not allow me to reply. This is the error message: mozes has private messaging disabled. You cannot send private messages to this user.
Hi
I didn't know that was a default: I can receive PMs now.
s.
Hi tllim
I sent you a private message.
s.
(11-14-2023, 04:03 AM)mozes Wrote: I disconnected the battery because it wouldn't turn on with it connected
If you connect the battery, the bypass power cables should be disconnected.
https://pine64.org/documentation/Pineboo...es/Caring/
"Connecting the bypass cables together effectively connects the charger input where the battery output is, which also bypasses the charging circuit inside the Pinebook Pro. Thus, with the bypass cables connected together, the charger powers the Pinebook Pro directly, just like the battery does it when the laptop is running on battery power. This also means that no input current limiting is any longer in place, making it possible to draw more than 3 A from the charger, and to trigger its overcurrent protection, which may cause operating system instability and crashes."
So when you are attempting to boot with battery connected, are the bypass cables disconnected?
  Replacement battery for PineBook Pro DrYak 5 9,607 02-28-2026, 09:17 PM
  Replacement touch pads Sb2024 0 2,847 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 7,239 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 3,854 10-14-2024, 05:35 PM
  Battery replacement mjc 2 6,786 09-26-2023, 01:08 AM
Last Post: david-lechner
  Replacement scissor switches (ANSI keyboard)? zackw 3 8,446 08-09-2021, 09:20 PM
  Pinebook Pro/Pinetab replacement as400 11 22,198 07-30-2021, 04:40 AM
Last Post: as400
  Replacement board avaliability mrjay 1 4,887 07-06-2021, 04:08 PM
  Minimum daughter boards/peripherals required for main board to boot cmicallef 5 9,783 03-12-2021, 10:10 PM
Last Post: cmicallef
  Replacement for video cable (EDP to LCD/camera)? pnwkayaker 2 7,083 10-13-2020, 08:42 PM
Last Post: pnwkayaker
