256GB EMMC!
Hello there,
I am just wondering if Pinebook Pro can handle 256GB emmc?
Has anyone try that?
I haven't tried it, but it should be possible. Because not all socketed eMMCs use the same sockets, you'll need to do some research to be sure you're getting the right module that can fit the PBP board. IIRC there are several socketed eMMCs from Ameridroid that will fit the PBP and several other Pine products. Unfortunately, I cannot recall which specific ones, but hopefully it'll be a good starting place.
https://www.hardkernel.com/shop/256gb-em...n2l-linux/ should work...
(11-18-2024, 09:53 AM)reukiodo Wrote: https://www.hardkernel.com/shop/256gb-em...n2l-linux/ should work...
You can also buy them from ameriDroid at https://ameridroid.com/products/emmc-mod...0927287575
  eMMC failed Dendrocalamus64 17 26,333 06-21-2025, 04:34 PM
  Hardkernel 256GB eMMC with lvm2 on PBP Dendrocalamus64 2 4,585 12-21-2024, 06:07 AM
  Upgrade eMMC card - boot problems alpopa 0 4,227 09-16-2020, 12:31 PM
Last Post: alpopa
  128GB eMMC support dgkPBP 7 15,540 09-08-2020, 07:36 AM
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 3,833 07-09-2020, 06:12 PM
Last Post: Spectre
  eMMC to USB adapter "very" slow at reading data talpa 3 9,297 07-08-2020, 08:55 AM
Last Post: talpa
  Internal installation of additional eMMC Besouro 7 15,161 06-06-2020, 09:33 PM
Last Post: xmixahlx
  Boot problems with new 128GB eMMC module Kareema 1 5,572 05-31-2020, 10:36 AM
Last Post: Kareema
Star Could you please add 128GB eMMC as a build option for this preorder? Dendrocalamus64 3 7,794 03-23-2020, 04:54 AM
Last Post: xmixahlx
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 7,590 03-04-2020, 01:20 PM
Last Post: zaius
