How to install arch with FDE
Hello, is there a way to install arch with FDE?
Full Disk Encryption?
(01-11-2024, 06:05 AM)SchizoPinePhone225 Wrote: Full Disk Encryption?
Yes, do you know how?
I believe it is is not officially supported. What is sure is that simply dd'ing the image onto microSD or eMMC storage (which is the recommended installation method) will not encrypt anything.
What should probably work is:
1. Install (dd) the image to a microSD card.
2. Copy a second copy of the image into the file system on the microSD card (an image inside the image, think Russian matryoshka dolls or Chinese boxes). The reason you want a second copy of the image is because it is a bad idea to copy a running system.
3. Boot the microSD card (i.e., the outer image) and use that to partition the eMMC with encrypted partitions. I guess you probably need an unencrypted /boot (because I do not think U-Boot can boot from LUKS partitions), but everything else can (or at least ought to be able to) be encrypted.
4. Mount the inner image on the microSD card:
sudo -i xz -d -k $IMG.img.xz mkdir -p /mnt/image mount -o loop,offset=512000512 $IMG.img /mnt/image mount -o loop,offset=32000000 $IMG.img /mnt/image/boot
5. Mount the encrypted (and unencrypted) partitions on the eMMC.
6. rsync the microSD contents to the eMMC. (The exact rsync command depends on how exactly it is partitioned, but you probably want at least the flags -aHAXr.)
7. Edit the system configuration on the eMMC (fstab, crypttab, etc.) to match how you partitioned it.
8. Remove the microSD, reboot, and hope that it works.
Someone somewhere might have script(s) to help you with that very manual procedure.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,275 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,219 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Updating Arch Linux _radv_ 8 9,623 02-20-2024, 09:35 AM
Last Post: _radv_
  How to find software app, on Arch Phosh? general_lee 5 9,174 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,466 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 4,018 07-29-2023, 08:27 AM
Last Post: alpineduck
  unable to install applications dln949 5 7,654 06-08-2023, 08:38 PM
Last Post: Conjada
  Latest update broke my install user641 8 11,036 02-22-2023, 05:54 AM
Last Post: gregb49
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 3,981 12-24-2022, 11:00 PM
Last Post: shulamy
  No keyboard on Arch Plasma when entering password on document Chief 0 3,379 12-03-2022, 08:35 PM
Last Post: Chief
