pinetab2 booting when adapter connected
With the U-Boot package updated to the latest version the device should automatically power off when you plug it into a power source when the device was in a powered off state.
Effectively the device no longer start when you plug it into a power source.
See https://github.com/dreemurrs-embedded/Pi...32d91e1f2b
(08-29-2023, 09:50 AM)Kwiboo Wrote: With the U-Boot package updated to the latest version the device should automatically power off when you plug it into a power source when the device was in a powered off state.
Aaaaaaaaaaahwesome! Heart Heart Heart Panik um sonst.
Can we just do a sudo pacman -S u-boot-tools or do we have to wait for a new image?
I took the ones from your u-boot-build repo dated 2023-08-06. Do they also have those fixes?
(08-29-2023, 10:12 AM)Ome Ko Wrote: Can we just do a sudo pacman -S u-boot-tools or do we have to wait for a new image?
I would recommend update all packages, e.g. pacman -Syu or similar, the u-boot-tools package probably only provide tools and not the actual U-Boot image.
Also possible there may be some dependencies on a newer kernel when U-Boot package is upgraded from the one provided from factory image.
(08-29-2023, 11:27 AM)diederik Wrote: I took the ones from your u-boot-build repo dated 2023-08-06. Do they also have those fixes?
That build should also have these fixes.
Look like I forgot to build my latest rk3568-2023.07.02-81dac03 tag, have triggered a new build now, my bad :-)
Code diff at https://github.com/Kwiboo/u-boot-rockchi...02-81dac03
Does not look to affect anything for PineTab2, only Radxa CM3-IO board to my knowledge.
Thanks! Only added those yesterday to my local git repo, so I'll update them anyway Big Grin
Got the U-boot-update this morning and failed to reboot using the powercable :-). Thanks again guys!
Gonna be charging this baby cycling from Harlingen to Elburg today....
Marked as solved.
  PineTab2 spec for ddr and rth 0 3,259 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 25,197 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 4,721 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 17,813 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 4,397 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 7,684 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 6,075 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 3,032 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 2,957 10-14-2023, 05:48 PM
Last Post: lockedpotato
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 10,071 09-06-2023, 07:43 PM
Last Post: bacon_dude
