Pine Desktop PowerSupply wont power on
Anyone else have a dead desktop 120W power supply?  It would occassionally flicker when I first got it, but seemed stable enough (dumb, I know).  Now its just kaput.
I dont know if anyone has had one die and got it back running again?  I love the little unit was great for my Pinebook and Pi/Arduinos.
Wondering if I just got a bad unit that I should have returned?  or worth fixing?
Thank!
I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
(04-23-2023, 02:31 PM)fxc Wrote: I would advise against opening a power supply, as this can be dangerous. Probably best to open a ticket under https://support.pine64.org
Thats probably a good call. Smile  Do you know if failure rate in them is high? or low?
Here at the community we don't really have insight in that. From people often asking in the chat etc. I would say issues are more common than with other Pine devices but I know that the power supply has upgraded internals over the OEM design to increase the life span.
The 120W PinePower failure rate is quite low.
I've never had trouble like this myself, contact support
Tower Defense
Got the same problem, did you find a solution?
  What about a Pine digital audio player? ClairelyClaire 8 11,738 02-08-2026, 08:11 PM
Last Post: gwennelsonuk
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 1,779 10-03-2025, 11:35 AM
Last Post: cowsay
  Pine.org very poor review rma00 9 12,276 07-07-2025, 12:06 PM
Last Post: dachalife
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,737 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 4,109 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,724 04-08-2025, 08:31 PM
Last Post: colajuices
  Help with high voltage power supply setup for electrospinning? namarang 2 5,250 10-13-2024, 09:38 AM
Last Post: zetabeta
  Desktop ready? eiger3970 0 1,931 07-27-2024, 07:49 PM
Last Post: eiger3970
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 3,066 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 3,078 04-02-2024, 11:11 PM
Last Post: evilbunny
