Is the USB 3.0 port still an issue for Q64 model A?
Does anyone know if the comment in the development wiki is still accurate?
From https://wiki.pine64.org/wiki/Quartz64_Development :
Confirmed Broken
  • USB 3.0 (applies to Model A only) — only works with very short cables and depends on the device. This is due to a hardware design issue relating to the coupling capacitors needed for SATA, which shares the same lines as USB 3.0.
    • Hardware design changes have been suggested to engineers, it's in their hands now.
I got a Quartz64 model A about a month ago and am now wondering if some issues I've been seeing with my board may be related to the USB 3.0 port.
Only if your board is one with a SATA port. If the SATA port is unpopulated, it should no longer be an issue.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
Thanks CounterPillow! I never enabled the SATA usage per the wiki. Do I actively need to do anything to ensure SATA is disabled?
I switched my drive to USB2 and since then the machine has been stable even for long time of data transfer.
This makes me think there is an issue with the USB3 port, or that the board has a different issue with high speed data transfer (e.g. getting overheated). But it's in an aluminium cooling case which should be OK according to the wiki. Temperature is stable around 66/67 degrees Celsius.
(12-10-2023, 08:55 PM)emmausa Wrote: According to the information I found, the USB 3.0 port problem on the Q64 A model has been resolved in the 1.0.2 firmware update. This update fixes an issue that caused USB 3.0 ports to be slow or not work. Suika game
Where can one find that firmware (update)?
  Quartz64 Model A fan TeutonicTovarish 2 4,979 07-08-2024, 07:19 AM
Last Post: p1x3l3d
  A large 3d printable case for Model A, or a dimensioned drawing of the PCB? Randomuser 1 2,895 05-24-2024, 08:11 AM
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 3,179 11-19-2023, 01:04 AM
Last Post: stormwyrm
  Survey for Model B Owners: Stereo Audio HAT CounterPillow 1 4,447 03-01-2023, 05:48 AM
Last Post: manning
  SD card slot in Quartz64 model B psic4t 1 4,061 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 3,737 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 5,601 10-05-2022, 02:01 PM
Last Post: pitchbent
  RockPro64 NAS case compatibility (Model A) flocke 2 6,409 06-12-2022, 10:33 AM
Last Post: flocke
  Case for the Quartz64 Model B? kuleszdl 1 5,561 06-05-2022, 02:43 PM
Last Post: CounterPillow
