A large 3d printable case for Model A, or a dimensioned drawing of the PCB?
Does anyone know of a large 3d printable case for a Quartz64 Model A that could fit a Pcie card and approximately one 3.5in hdd in addition to the board? I'm not actually putting in a drive, I just need about this much space.
I'd use the PinePro 64 metal case as it is ideal size, but I'm not a fan of the construction that puts one of thewalls offsett from another internal wall, then there is a huge square hole... It signifficantly lowers the usability of that case for me.
Alternatively if someone has a dimensioned drawing of the mounting pattern for Quartz64 Model A please share. I can make my own.
(05-24-2024, 07:15 AM)Randomuser Wrote: Does anyone know of a large 3d printable case for a Quartz64 Model A that could fit a Pcie card and approximately one 3.5in hdd in addition to the board? I'm not actually putting in a drive, I just need about this much space.
you can find some printable files to modify to your needs in this section of the board documentation page: https://pine64.org/documentation/Quartz6...atasheets/
  Quartz64 Model A fan TeutonicTovarish 2 4,938 07-08-2024, 07:19 AM
Last Post: p1x3l3d
  Is the USB 3.0 port still an issue for Q64 model A? andreas1107 3 5,492 12-11-2023, 09:27 AM
Last Post: diederik
  SOQuartz Model A baseboard Real-Time Clock stormwyrm 1 3,142 11-19-2023, 01:04 AM
Last Post: stormwyrm
  Survey for Model B Owners: Stereo Audio HAT CounterPillow 1 4,400 03-01-2023, 05:48 AM
Last Post: manning
  SD card slot in Quartz64 model B psic4t 1 4,023 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 3,708 10-13-2022, 07:43 PM
Last Post: dml-pc
  3D Model / Technical Drawings pitchbent 2 5,552 10-05-2022, 02:01 PM
Last Post: pitchbent
  Open acrylic case olivercfc 0 3,503 07-09-2022, 04:53 PM
Last Post: olivercfc
  RockPro64 NAS case compatibility (Model A) flocke 2 6,359 06-12-2022, 10:33 AM
Last Post: flocke
  Case for the Quartz64 Model B? kuleszdl 1 5,523 06-05-2022, 02:43 PM
Last Post: CounterPillow
