Battery life thread: discussion, support and tips
This is an invitation to discuss the status and development of ppp battery life using various software configurations.  Please feel free to let us know the following;
    -the os you are using,
    -your battery life performance:
        -idle performance,
        -active use performance,
    -any tweaks or settings that helped with your system.
I am currently using postmarketos edge and getting around 4 hours battery life while suspended and around 1 hour while doing light browsing, depending on screen brightness.
        -idle performance,
I use Arch/sxmo mainly, also Arch/phosh (See setup details here.)
In suspend mode get way more than 24 hours - would need to check Megi's pages but think he calculated 36 or so theoretically. I much prefer sxmo in general, but specifically to suspend you KNOW it is suspended when the LED stops flashing!
Active use (browsing, email, telegram, some mpv) maybe 3-4 hours
Note the default cpu governor in Danct12 Arch images is conservative: I change my default to schedutil as don't see the point of permanently doping my cpu. In theory bad for battery but what I get is still fine.
Hoping that I can improve my active use life if I can get Megi's DRAM scaling working.
(08-10-2023, 03:40 AM)dukla200 Wrote: I use Arch/sxmo mainly, also Arch/phosh (See setup details here.)
I just put arch/phosh on the microsd card and am getting a long life (24 hours or more) in suspend mode.  However the ppp is not picking up phone calls.  Is this the same experience you are having, dukla200?  Or do you get 24 hours battery life with phone capabilities while on suspend?
(08-12-2023, 12:04 AM)apink Wrote: I just put arch/phosh on the microsd card and am getting a long life (24 hours or more) in suspend mode.  However the ppp is not picking up phone calls.  Is this the same experience you are having, dukla200?  Or do you get 24 hours battery life with phone capabilities while on suspend?
For me it has been impossible to get calls trough with stock modem firmware while suspended - usb connection resets every time and it happens with all distros.
With Biktorgjs firmware and recommended settings it works at least in Arch Phosh and Pmos phosh.
https://github.com/the-modem-distro/pinephone_modem_sdk
how many hours do you get whilst receiving calls?
(09-22-2023, 05:58 AM)tookmeayear Wrote: how many hours do you get whilst receiving calls?
If you mean that the phone just sits suspended and only modem is alive waiting for calls or sms it will be something between 36-48 hours.
It depends how good network is and is the phone still or moving (like in car or sitting in the office desk).
Thank you, this makes it usable for me then. I will try again.
i canmake calls and recieve them, but no sound at either end, trying to fix that prpb and i think itll be ok. I can text, sms and send images via the chat but only after setting the right apn for my carrier which is att. both spn settimgs are set to NXTGENPHONE litterally.
        -idle performance,
I made a jig so that I can measure current draw at the battery while using the phone, here are the results:
- PostmarketOS phosh 24.12:
  - Screen on, brightness 50%, airplane mode: ~800mA while interacting, ~550mA idle
  - Screen off: 360mA
  - Suspend: 300mA (with suspend enabled in the power menu)
  - Balance/Performance power profiles did not seem to make any noticeable difference to current draw
- Mobian weekly build (20250119): I didn't measure the current through the jig for this, but it seems similar to pmOS except for suspend (if you enable suspend in the menu) which drops the idle current very low for long standby times! Will hopefully measure this at some point.
So as far I can tell, don't expect more than about 4.5 hours of screen-on time (this chip is power hungry!) and pmOS doesn't suspend properly so the battery will die in about 10 hours or less even with the screen off. Mobian gives long standby times.
As I mentioned in another thread, there are issues with the battery "fuel gauge" where after about 30 mins from fully charged of heavy use (e.g. youtube playback) it says there's only 5% battery left, but if you take out the battery and check voltage, it's still at about 50% capacity, and if you wait (between 10 min and 50 mins) and put the battery back in, the phone will then say there's 50% capacity. The battery voltage, although it fluctuates a lot based on load, is a better indicator of capacity (when not charging, 4.0v is about 100% and 3.1v is about 0%).
(01-24-2025, 08:56 AM)teekay Wrote: ...
Yup - I have also noticed pmOS drains my PPP much faster than anything else. Just discovered it appears to be running the cores at full speed the whole time even when idle!
# cat /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor ondemand # cat /sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq 1500000 # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq 1008000
  Experimental Mobian kernel patch for extended battery life teekay 15 17,017 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,017 10-20-2025, 07:01 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 63,623 10-13-2025, 07:46 AM
Last Post: Habbytm
  Battery Management on PinePhonePro: d50zesl0g@mozmail.com 4 4,974 03-02-2025, 11:52 AM
Last Post: d50zesl0g@mozmail.com
  Reseting the Battery Fuel Gauge franzthiemann 8 8,907 01-24-2025, 08:19 AM
Last Post: teekay
  [Mobian] : Battery consumption and OS compatibility freelectro 2 3,872 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 5,527 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 4,666 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  Mobian has new separate packages to support the PinePhone Pro mburns 22 24,987 04-10-2023, 12:02 PM
Last Post: mburns
  Battery meter slowly reducing under keyboard charger robocone 1 3,592 12-26-2022, 09:37 AM
Last Post: robocone
