Mobian .desktop file creation
(07-22-2023, 01:34 PM)MadameMalady Wrote: So, that does make the icon show up correctly, but it doesn't run any of the commands in the opened terminal bc it's read-only, is that related at all or a different issue?
I am not that familiar with Python but I think it might work if you put the exec line like this:
Exec=bash -c 'cd /home/mobian/MyWaydroidManager/ && python3 MyWaydroidManager.py'
or
Exec=python3 /home/mobian/MyWaydroidManager/MyWaydroidManager.py
or maybe Big Grin
Exec=/usr/bin/env python3 /home/mobian/MyWaydroidManager/MyWaydroidManager.py
Just throwing curve balls but either of those should not make any harm so feel free to try Smile
If your desktop file does not open terminal at all you might want to install gnome-terminal and try then again Smile (recent versions of console will support opening trough desktop files but that is not the case with all version)
or
or maybe Big Grin
Thanks for taking the time to help with this, I tried all three of those and I still get a terminal that opens to a Read-Only file system, and tells me it cant 'cd to scripts'
-_-.....
So close to figuring this out..
(07-23-2023, 02:53 PM)MadameMalady Wrote: Thanks for taking the time to help with this, I tried all three of those and I still get a terminal that opens to a Read-Only file system, and tells me it cant 'cd to scripts'
-_-.....
Then the issue must be in the python script?
Because there are no cd command to scripts.
So now you should be at the point where your desktop file will execute your python script but the script somehow fails Smile
-_-.....
I figured it out after a week of debugging, it was not the python program but the bash scripts, the directories they created with my installer were made with sudo, which was the cause of my issues
(07-27-2023, 02:09 PM)MadameMalady Wrote: So now you should be at the point where your desktop file will execute your python script but the script somehow fails Smile
Awesome. I am really looking forward your app. I did try the old one some time a go and the idea is awesome.
With PP it is bit too slow but I think your work is really valuable and people will love it when it become ready Smile
Thank so much!
I've been working hard on it, and so far It works pretty well on Ubuntu, Debian, and Mobian, but additional distros and options are a work in progress. Big Grin
  Experimental Mobian kernel patch for extended battery life teekay 15 16,554 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 21,310 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,630 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 8,878 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,117 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,089 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,045 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,794 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 2,775 11-09-2023, 07:39 AM
Last Post: mburns
  Fix the Mobian Weather App mburns 0 1,948 11-07-2023, 10:01 AM
Last Post: mburns
