Mobian .desktop file creation
I'm trying to write a temporary installer for a program I'm working on, and none of the .desktop files I have created have shown up on Phosh on Mobian
I've tried:
~/.local/share/applications/
and
/home/mobian/.local/share/applications
as locations for the .desktop files, and it *still* doesn't show up..
I've made desktop files before on Manjaro Phosh, and didn't have any of these struggles, any help would be appreciated, i've been working on this for hooooooours @_@
Since those paths looks okay could you paste what is inside your .desktop file Smile?
#!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Exec=/home/mobian/MyWaydroidManager/MyWaydroidManager.py
X-Purism-FormFactor=Workstation;Mobile;
Name=My Waydroid Manager
Comment=Manage Waydroid installations easily
Icon=/home/mobian/MyWaydroidManager/icons/icon.svg
Categories=utility
(07-20-2023, 01:14 PM)alaraajavamma Wrote: Since those paths looks okay could you paste what is inside your .desktop file Smile?
(07-20-2023, 03:05 PM)MadameMalady Wrote: #!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility
Remove the bin bash Smile
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility
I've tried that too and I didn't have luck Sad
Here's the whole option in the script, maybe i'm messing something up..?
if [ $(hostname) = 'mobian' ]; then
  notify-send "My Waydroid Manager" "Check Your Terminal"
  # copy application directory
  cd ..
  sudo mkdir -p /home/mobian/MyWaydroidManager
  sudo cp My_Waydroid_Manager.py /home/mobian/MyWaydroidManager
  sudo cp -r icons /home/mobian/MyWaydroidManager
  sudo cp -r scripts /home/mobian/MyWaydroidManager
  cd  ~/.local/share/applications/
  sudo touch MyWaydroidManager.desktop
  echo "#!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility">MyWaydroidManager.desktop
this option is in a directory called scripts, since the program is in 'scripts' when this option is ran, I have it cd .. back up a directory to start.
The #!/bin/bash definitely does not make sense, use #!/usr/bin/xdg-open or #!/usr/bin/env xdg-open or no #! at all.
(07-21-2023, 07:32 AM)Kevin Kofler Wrote: The #!/bin/bash definitely does not make sense, use #!/usr/bin/xdg-open or #!/usr/bin/env xdg-open or no #! at all.
Tried without any shebang at all (still no luck at all) , what's xdg-open do? / what/s xdg?
[Desktop Entry]
Version=0.1.9
Terminal=true
Type=Application
Try if this works. Also make sure that you have written the file name correctly like mywaydroidmanager.desktop
(07-21-2023, 10:22 AM)alaraajavamma Wrote:
[Desktop Entry]
Version=0.1.9
Terminal=true
Type=Application
I ended up putting the X-purism line right after the icon like, but that worked, thanks!
now to figure out how to prevent it from making the buttons smaller bc it opened the terminal first.. ?
So, that does make the icon show up correctly, but it doesn't run any of the commands in the opened terminal bc it's read-only, is that related at all or a different issue?
xdg-open opens a document with the document opening tool provided by your desktop environment. (xdg stands for "Cross-Desktop Group".) This works for files such as word processor documents or spreadsheets, but also for .desktop files. So if you want to make the .desktop file executable as a script, that is the tool for it. But there is generally no need to make .desktop files directly executable at all.
  Experimental Mobian kernel patch for extended battery life teekay 15 14,724 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 18,715 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,069 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 7,765 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 1,813 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 4,525 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 1,833 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,443 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 2,549 11-09-2023, 07:39 AM
Last Post: mburns
  Fix the Mobian Weather App mburns 0 1,758 11-07-2023, 10:01 AM
Last Post: mburns
