Broke pinebook GUI, what to do, fix or install new?
So a while back I managed to break the stock Neon OS when trying to switch from Plasma to something else. There was some change I did to systemctl and it broke it. It will boot to a command prompt. I set it aside and ignored it for a while.
I know Neon has been out of style for a while so I don't know how much effort I should put into fixing it, or should I just put something else on it?
I'm noticing that there isn't a nice list of "mainstream" Linux operating systems for it like there is for the Pinebook Pro, which sucks.
Is there an OS I can install onto it without it being to hacky to get it working? I just want something I can use instead of having to tinker with all the time.
At the moment I'm using NetBSD from a SD card but I have to use a different WiFi adapter.
Thanks!
They are community builds, not official, but Armbian will likely be a solid bet for getting an OS you don't have to tinker with, getting up and going quickly.
https://www.armbian.com/pinebook-a64/
(07-10-2023, 07:39 AM)tophneal Wrote: They are community builds, not official, but Armbian will likely be a solid bet for getting an OS you don't have to tinker with, getting up and going quickly.
I installed Armbian with XFCE onto an SD card and it's not perfect but it works. Pretty neat. I'm typing this on it right now. Thanks.
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,189 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,078 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,685 09-26-2023, 03:18 PM
  Orignal PineBook jwp1000 1 4,754 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,571 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,764 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,118 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,865 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,787 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 6,360 12-25-2020, 04:40 PM
Last Post: ford442
