Screen stay black unless power key pressed short
Hi all,
Few times the screen stay black when i short pressed power key.
The first situation let thinking about SWAP problem.
juin 24 07:51:53 mobian kernel: get_swap_device: Bad swap offset entry e80000cbfd8f
The problem appear line 6694 until the end of file 700038.
https://debian-facile.org/paste-D2EF27DD...8e0853f531
The second situation, you can analyze the journalctl log at the end line 8074.
This is at this step i tried to press power key short to wake-up my pinephone.
https://debian-facile.org/paste-867262EE...32f07ffd6d
I have seen this two lines, but maybe it's not their.
juin 24 15:30:34 mobian gsd-xsettings[1224]: Failed to get current UI legacy scaling factor juin 24 15:30:32 mobian kernel: Freezing remaining freezable tasks
If you have an idea about this problem ! Thank you a lot
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,686 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,443 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,065 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,486 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,661 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,685 01-15-2025, 08:08 PM
  Short Guide to Using OpenVPN client GUI and .ovpn config file on PP biketool 0 6,752 12-16-2024, 02:07 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,849 08-05-2024, 06:12 AM
Last Post: baptx
  Screen auto-rotation sensitivity mdk 0 2,551 12-26-2023, 06:08 AM
Last Post: mdk
  Power Consumption on Suspend JudgeFudge 8 8,659 07-29-2023, 06:24 AM
Last Post: JudgeFudge
