Udating the firm,ware? Potential problems?
So I am reading over on UBPorts about updating the firmware which results in a different boot loader. Going from Uboot to Tow-boot
https://ubports.com/en/blog/ubports-news...e-pro-3889.
Is this a problem for any other distros out there for the PinePhone?
The original PinePhone (unlike the PinePhone Pro) does not have an SPI flash dedicated for booting (the text in your link that claims you should install the Tow-Boot to the SPI on the PinePhone is wrong, the accompanying screenshot is from a PinePhone Pro), so Tow-Boot is installed to the eMMC or to a microSD card. Which means that if you install a distro which comes with its own bootloader (usually its own build of u-boot) the common way (by overwriting the eMMC or microSD card contents with the distro image), you will be overwriting Tow-Boot with that distro's bootloader anyway. So it should not matter at all. (And besides, those distros normally boot just fine with Tow-Boot too.)
Thanks. I'll give it a try.
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 9,914 06-30-2023, 11:39 PM
Last Post: ionmich
Question Modem problems with the distros I tried UltraBlack_ 9 12,409 02-21-2022, 01:57 PM
Last Post: KNERD
  Problems with Pinephone camera ov5640 wfk 0 2,685 06-29-2021, 01:53 AM
Last Post: wfk
Sad Problems with PINE64 Support Astilex 1 4,634 04-05-2021, 12:48 AM
  some problems aditus@einet.bg 4 9,082 09-16-2020, 08:57 AM
Last Post: BZHDeveloper
  Problems with new PinePhone LinAdmin 7 15,137 09-08-2020, 06:28 PM
Last Post: SwordfishII
  Problems with UBPorts downloads bcnaz 8 14,063 07-21-2020, 08:47 PM
Last Post: bcnaz
  Problems with customs clearance jacksondaniels 1 4,430 07-06-2020, 12:35 AM
Last Post: dolsonlelan
  My pinephone problems/questions xinyiman 3 8,114 06-30-2020, 03:16 AM
Last Post: xinyiman
