2TB SD Card Write Errors
Per the booklet, I got the largest SD card compatible with the Pinebook Pro. I can successfully format, check it for errors and mount it. As soon as a write attempt is made, even just a mkdir, errors occur (invalid block bitmap). I've tried both ext4 and ext3.
Has anyone had success mounting and using that large an SD card? Thanks.
You probably don't want to hear me kvetch any further about Manjaru, but have you read these threads?
https://forum.pine64.org/showthread.php?...=Sd+errors
:wq
(06-02-2023, 03:56 PM)KC9UDX Wrote: You probably don't want to hear me kvetch any further about Manjaru, but have you read these threads?
Actually, I think this one is my fault... I could have sworn I'd read that ext3 and 4 had been supported on SD cards. I've reformatted to fat32, and am doing further testing.
It *should* work with ext3, ext4, etc. I use UFS and PFS3. But not with Manjaru. I'm pretty sure I have used ext2 or ext3 with Manjaru, but that was before the update when people started reporting that it didn't work. Granted I've never used an SD card larger than 128Gb.
:wq
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,111 03-10-2025, 01:55 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,443 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Bootloader: SD card boot quirks crazyquark 1 3,312 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Unable to make a bootable microSD card myself600 15 16,529 09-27-2022, 01:45 PM
Last Post: myself600
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 29,589 08-18-2022, 11:26 PM
Last Post: calinb
  Ungoogled Chromium on a Pinebook Pro won't run - OpenGL errors? pinemouth 2 6,759 12-09-2021, 02:23 PM
Last Post: pinemouth
  Debian/unstable SD card rescue image vajak 4 9,326 10-28-2021, 02:53 PM
Last Post: vajak
  UBOOT Errors after flashing new os to mmc aechanio 4 9,535 08-18-2021, 07:07 PM
Last Post: aechanio
  PBP won't boot from eMMC or SD card: a saga archaicmeander 18 28,986 02-06-2021, 07:40 PM
  UBOOT - Mainline not booting from SD card / BSP OK Anarethos 1 6,401 01-10-2021, 12:33 AM
Last Post: Anarethos
