No Video Out on PBP on all major distros
Sad reality, but video out on pinebook pro was regressed on all major distros
this includes default factory os manjaro
Found some info that kernel patches needed to allow video out were dropped since were hard to maintain
I guess with years interest for PBP dropped, as well as support for basic functionality from developers.
For example, cannot believe that in 2019 there was mrfixit debian build with all the working functionality that you could easily flash to sd card, while now 4 years later you cannot connect pbp to external monitor or tv
Any suggestions how to make it work again would be appreciated
Does it work on any minor distrus?
Perhaps NetBSD is in a better situation: HDMI video output never worked, but we are still looking forward to having it working.
:wq
Sorry, i dont have a fix. Just wanted to add my voice, i am hoping for a fix to this also, posted about this issue a year or so ago.
It actually used to work when i first got the pbp, it stopped working directly after an update. I dont remember which one. This is on the shipped manjaro.
(05-28-2023, 02:39 AM)KC9UDX Wrote: Does it work on any minor distrus?
I tried:
manjaro
armbian
ubuntu
endeavouros
postmarketos
fedora
feels like a waste of time, to be honest
some bits of info online mention difficulty developers had maintaining patches for video out, so they dropped:
https://gitlab.com/postmarketOS/pmaports/-/issues/1778
I do maintain for myself changes that were once present in https://github.com/megous/linux, though I can't find them anymore there, and with some additional small fixes HDMI works fine for me for quite some time. Currently on 6.3.4:
https://github.com/pld-linux/kernel/blob...-pro.patch
(05-30-2023, 06:27 AM)jpalus Wrote: I do maintain for myself changes that were once present in https://github.com/megous/linux, though I can't find them anymore there, and with some additional small fixes HDMI works fine for me for quite some time. Currently on 6.3.4:
great, thanks for the suggestion
you apply patch on manjaro kernel?
also out of curiosity, can you get 4k or 1080 resolution out of pbp display out?
(05-30-2023, 01:24 PM)misha64 Wrote: you apply patch on manjaro kernel?
Nope that's a patch from kernel built in PLD Linux. But I don't see any reason why it couldn't be applied against Manjaro kernel.
(05-30-2023, 01:24 PM)misha64 Wrote: also out of curiosity, can you get 4k or 1080 resolution out of pbp display out?
Biggest screen I hook up into PBP is 2560x1440 and it drives it just fine.
Let us be realistic here.
There is working alt-dp support in Manjaro but only if you use the special Pinephone pro kernel which unfortunately has no NVME support
My experience so far over countless hours with my Pinebook Pro has been one of solid fail in that
1) My board revision is apparently new and does not match the pictures on the wiki which caused initial confusion when installing Armbian
2) Attempts to use the patched kernels for the pinebook pro fail. Type C DP port negotiation appears to work even with mainline 6.1 and 6.3 kernels and will try and initialise the display port but negotiation fails between the fusb230 and the Rockchip cpu. This does not happen with the pinephone pro kernel in Manjaro
This suggest there has been a hardware change to where the i2c port for the fusb230 is located as my kernel reports in Armbian that there is no i2c connection to the fusb230.
However everything else functions correctly.
Any updates on this? Trying to roll my own kernel on Gentoo for the PBP but I haven't been able to get DP out working
(10-02-2023, 10:05 AM)kebab Wrote: Any updates on this? Trying to roll my own kernel on Gentoo for the PBP but I haven't been able to get DP out working
Please see here:  https://forum.pine64.org/showthread.php?...#pid120527
  Inexpected reboot during watching youtube video regivanx 1 3,030 10-19-2024, 06:02 AM
  (xorg) Video driver? falken 2 4,142 07-03-2024, 12:01 PM
Last Post: falken
  Streaming video sites tessa 1 3,059 01-19-2024, 03:47 AM
Last Post: similarwham
Brick Are there any usable/ stable distros for PBP? pineymousepad 16 17,332 05-24-2023, 10:06 AM
Last Post: Vinay
  Manjaro update broke hardware video acceleration with mpv myself600 2 4,561 01-25-2023, 09:12 AM
Last Post: myself600
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 3,741 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
Sad 1080p60 video on PBP Linux chewie 2 6,410 08-03-2021, 09:43 AM
Last Post: chewie
Bug 4K@30 video output does not work properly on Pinebook Pro jkm 0 3,875 06-29-2021, 08:43 AM
Last Post: jkm
Lightbulb Hardware video acceleration in Chromium on Manjaro siemsenit 3 8,906 06-01-2021, 09:51 AM
Last Post: siemsenit
  Very bad video playback ksinar 1 5,229 11-23-2020, 08:34 PM
Last Post: xyzzy
