RXDP from Win10 to Armbian on Rock64
i dont know much about Linux but i tryed anythink i could find, but with no sucsess...
I want to use Windows XRDP Remote to connect but it only works with root. Why
This is the log from  XRDP and Sesman, firstr try is a user, second try is root
Quote:xrdp:
[20230524-20:56:31] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 49328
[20230524-20:56:31] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230524-20:56:31] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230524-20:56:31] [ERROR] SSL_read: I/O error
[20230524-20:56:31] [ERROR] libxrdp_force_read: header read error
[20230524-20:56:31] [ERROR] Processing [ITU-T T.125] Connect-Initial failed
[20230524-20:56:31] [ERROR] [MCS Connection Sequence] receive connection request failed
[20230524-20:56:31] [ERROR] xrdp_sec_incoming: xrdp_mcs_incoming failed
[20230524-20:56:31] [ERROR] xrdp_rdp_incoming: xrdp_sec_incoming failed
[20230524-20:56:31] [ERROR] xrdp_process_main_loop: libxrdp_process_incoming failed
[20230524-20:56:31] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230524-20:56:31] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230524-20:56:31] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 49329
[20230524-20:56:31] [INFO ] Connected client computer name: DELLG515SE
[20230524-20:56:31] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc006 is unknown (ignored)
[20230524-20:56:31] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc00a is unknown (ignored)
[20230524-20:56:31] [INFO ] xrdp_load_keyboard_layout: Keyboard information sent by the RDP client, keyboard_type:[0x04], keyboard_subtype:[0x00], keylayout:[0x00000407]
[20230524-20:56:31] [INFO ] xrdp_load_keyboard_layout: model [] variant [] layout [de] options []
[20230524-20:56:31] [INFO ] TLS connection established from ::ffff:192.168.1.145 port 49329: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230524-20:56:31] [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
[20230524-20:56:31] [INFO ] xrdp_process_offscreen_bmpcache: support level 1 cache size 10485760 MB cache entries 100
[20230524-20:56:31] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20230524-20:56:31] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20230524-20:56:31] [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
[20230524-20:56:31] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20230524-20:56:31] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20230524-20:56:43] [INFO ] connecting to sesman ip 127.0.0.1 port 3350
[20230524-20:56:43] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230524-20:56:43] [INFO ] sesman connect ok
[20230524-20:56:43] [INFO ] sending login info to session manager, please wait...
[20230524-20:56:43] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20230524-20:56:43] [INFO ] login successful for display 10
[20230524-20:56:43] [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
[20230524-20:56:43] [INFO ] started connecting
[20230524-20:56:43] [INFO ] lib_mod_connect: connecting via UNIX socket
[20230524-20:59:54] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 49873
[20230524-20:59:54] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230524-20:59:54] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230524-20:59:54] [ERROR] SSL_read: I/O error
[20230524-20:59:54] [ERROR] libxrdp_force_read: header read error
[20230524-20:59:54] [ERROR] Processing [ITU-T T.125] Connect-Initial failed
[20230524-20:59:54] [ERROR] [MCS Connection Sequence] receive connection request failed
[20230524-20:59:54] [ERROR] xrdp_sec_incoming: xrdp_mcs_incoming failed
[20230524-20:59:54] [ERROR] xrdp_rdp_incoming: xrdp_sec_incoming failed
[20230524-20:59:54] [ERROR] xrdp_process_main_loop: libxrdp_process_incoming failed
[20230524-20:59:54] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230524-20:59:54] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
[20230524-20:59:54] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.145 port 49874
[20230524-20:59:54] [INFO ] Connected client computer name: DELLG515SE
[20230524-20:59:54] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc006 is unknown (ignored)
[20230524-20:59:54] [WARN ] Received [MS-RDPBCGR] TS_UD_HEADER type 0xc00a is unknown (ignored)
[20230524-20:59:54] [INFO ] xrdp_load_keyboard_layout: Keyboard information sent by the RDP client, keyboard_type:[0x04], keyboard_subtype:[0x00], keylayout:[0x00000407]
[20230524-20:59:54] [INFO ] xrdp_load_keyboard_layout: model [] variant [] layout [de] options []
[20230524-20:59:54] [INFO ] TLS connection established from ::ffff:192.168.1.145 port 49874: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230524-20:59:55] [INFO ] xrdp_caps_process_pointer: client supports new(color) cursor
[20230524-20:59:55] [INFO ] xrdp_process_offscreen_bmpcache: support level 1 cache size 10485760 MB cache entries 100
[20230524-20:59:55] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20230524-20:59:55] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20230524-20:59:55] [INFO ] xrdp_caps_process_codecs: RemoteFX, codec id 3, properties len 49
[20230524-20:59:55] [INFO ] Loading keymap file /etc/xrdp/km-00000407.ini
[20230524-20:59:55] [WARN ] local keymap file for 0x00000407 found and doesn't match built in keymap, using local keymap file
[20230524-21:00:03] [INFO ] connecting to sesman ip 127.0.0.1 port 3350
[20230524-21:00:03] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230524-21:00:03] [INFO ] sesman connect ok
[20230524-21:00:03] [INFO ] sending login info to session manager, please wait...
[20230524-21:00:03] [INFO ] xrdp_wm_log_msg: login successful for display 10
[20230524-21:00:03] [INFO ] login successful for display 10
[20230524-21:00:03] [INFO ] loaded module 'libxup.so' ok, interface size 10296, version 4
[20230524-21:00:03] [INFO ] started connecting
[20230524-21:00:03] [INFO ] lib_mod_connect: connecting via UNIX socket
[20230524-21:00:04] [INFO ] lib_mod_log_peer: xrdp_pid=2133 connected to X11rdp_pid=2591 X11rdp_uid=0 X11rdp_gid=0 client_ip=::ffff:192.168.1.145 client_port=49329
[20230524-21:00:04] [INFO ] connected ok
[20230524-21:00:04] [ERROR] SSL_write: I/O error
[20230524-21:00:04] [ERROR] xrdp_sec_send_fastpath: xrdp_fastpath_send failed
[20230524-21:00:04] [ERROR] xrdp_rdp_send_fastpath: xrdp_sec_send_fastpath failed
[20230524-21:00:04] [ERROR] libxrdp_set_pointer: xrdp_rdp_send_fastpath failed
[20230524-21:00:04] [INFO ] lib_mod_log_peer: xrdp_pid=2564 connected to X11rdp_pid=2591 X11rdp_uid=0 X11rdp_gid=0 client_ip=::ffff:192.168.1.145 client_port=49874
[20230524-21:00:05] [ERROR] xrdp_iso_send: trans_write_copy_s failed
[20230524-21:00:05] [ERROR] Sending [ITU T.125] DisconnectProviderUltimatum failed
sesman:
20230524-20:56:43] [INFO ] Socket 8: AF_INET6 connection received from ::1 port 33556
[20230524-20:56:43] [INFO ] Terminal Server Users group is disabled, allowing authentication
[20230524-20:56:43] [INFO ] ++ created session (access granted): username test2, ip ::ffff:192.168.1.145:49329 - socket: 12
[20230524-20:56:43] [INFO ] starting Xorg session...
[20230524-20:56:43] [INFO ] Starting session: session_pid 2134, display :10.0, width 1920, height 1080, bpp 24, client ip ::ffff:192.168.1.145:49329 - socket: 12, user name test2
[20230524-20:56:43] [INFO ] [session start] (display 10): calling auth_start_session from pid 2134
[20230524-20:56:43] [ERROR] sesman_data_in: scp_process_msg failed
[20230524-20:56:43] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20230524-20:56:44] [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20230524-20:56:54] [WARN ] Timed out waiting for X server on display 10 to startup
[20230524-20:56:54] [INFO ] Session started successfully for user test2 on display 10
[20230524-20:56:54] [INFO ] Starting the xrdp channel server for display 10
[20230524-20:56:54] [INFO ] Session in progress on display 10, waiting until the window manager (pid 2151) exits to end the session
[20230524-20:56:54] [ERROR] There is no X server active on display 10
[20230524-20:56:54] [ERROR] A fatal error has occured attempting to start the window manager on display 10, aborting connection
[20230524-20:56:54] [WARN ] Window manager (pid 2151, display 10) exited quickly (0 secs). This could indicate a window manager config problem
[20230524-20:56:54] [INFO ] Calling auth_stop_session and auth_end from pid 2134
[20230524-20:56:54] [INFO ] Terminating X server (pid 2152) on display 10
[20230524-20:56:54] [INFO ] Terminating the xrdp channel server (pid 2437) on display 10
[20230524-20:56:54] [INFO ] X server on display 10 (pid 2152) returned exit code 1 and signal number 0
[20230524-20:56:54] [INFO ] xrdp channel server for display 10 (pid 2437) exit code 0 and signal number 0
[20230524-20:56:54] [INFO ] cleanup_sockets:
[20230524-20:56:54] [INFO ] ++ terminated session:  username test2, display :10.0, session_pid 2134, ip ::ffff:192.168.1.145:49329 - socket: 12
[20230524-21:00:03] [INFO ] Socket 8: AF_INET6 connection received from ::1 port 45346
[20230524-21:00:03] [INFO ] Terminal Server Users group is disabled, allowing authentication
[20230524-21:00:03] [INFO ] ++ created session (access granted): username root, ip ::ffff:192.168.1.145:49874 - socket: 12
[20230524-21:00:03] [INFO ] starting Xorg session...
[20230524-21:00:03] [INFO ] Starting session: session_pid 2574, display :10.0, width 1920, height 1080, bpp 24, client ip ::ffff:192.168.1.145:49874 - socket: 12, user name root
[20230524-21:00:03] [INFO ] [session start] (display 10): calling auth_start_session from pid 2574
[20230524-21:00:03] [ERROR] sesman_data_in: scp_process_msg failed
[20230524-21:00:03] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20230524-21:00:04] [INFO ] Starting X server on display 10: /usr/lib/xorg/Xorg :10 -auth .Xauthority -config xrdp/xorg.conf -noreset -nolisten tcp -logfile .xorgxrdp.%s.log
[20230524-21:00:04] [INFO ] Found X server running at /tmp/.X11-unix/X10
[20230524-21:00:04] [INFO ] Session started successfully for user root on display 10
[20230524-21:00:04] [INFO ] Starting the default window manager on display 10: /etc/xrdp/startwm.sh
[20230524-21:00:04] [INFO ] Session in progress on display 10, waiting until the window manager (pid 2590) exits to end the session
[20230524-21:00:04] [INFO ] Starting the xrdp channel server for display 10
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,912 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 93,003 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,401 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,795 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,035 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,046 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,752 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,937 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,813 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 115,476 09-01-2024, 06:05 AM
Last Post: RaymondDay
