Pinephone - broken power button
(03-27-2023, 05:04 PM)kbm Wrote:
(05-02-2021, 07:30 AM)rorus Wrote:
(04-06-2021, 09:58 AM)KNERD Wrote:
(04-06-2021, 01:44 AM)ncc Wrote:
(04-05-2021, 04:21 PM)KNERD Wrote: The actual power and volume buttons are actually a part of the LCD screen.  When you order a new screen, they send you a tiny decal with contacts on it to short the membranes on those tiny contacts when you depress the plastic outside part.  $35USD
the part you are talking about is the "PINEPHONE SIDE KEYS FLEX PCB" and costs only 1 USD
I did not realize that was in the Pine Store (plus $15 shipping )
I ordered it (30/03) after reading the discussion, will let you guys know how the replacement goes when it arrives. Thanks everyone for your advice!
Were you able to replace this? Having a very similar issue with my power button
I was able to fix my PPP with this and everything is working again.
do i need to remove motherboard in order to replace power + volume button, or can i do without needing of replace motherboard?
can i replace power button + volume, without needed of remove motherboard, or is it necessary remove it. Because on ifixit it show i must remove motherboard, but the small part (1.00 EUR only) doesnt seem to me i must replace motherboard, not necessary it seems to me
(12-14-2024, 11:58 AM)idice Wrote: do i need to remove motherboard in order to replace power + volume button, or can i do without needing of replace motherboard?
You may not need to remove the motherboard.
I had broken power buttons on two pinephones. I tried glue, but fixed that using duct tape.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,701 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,653 08-23-2026, 12:17 AM
Last Post: Nambo
  PinePhone 16 GB – Free to a Good Home Anna 2 2,582 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,028 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,549 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,607 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,137 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,309 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 3,900 03-25-2025, 08:51 PM
  various tricks to open the pinephone shengchieh 3 6,332 09-16-2024, 03:42 AM
