5G for the Pinephone?
With the release of the Explorer Edition, is there or are there going to plans to update our modem to a 5g modem, or should I just save money to get the newer phone?
(05-15-2023, 12:27 AM)antiwesley Wrote: With the release of the Explorer Edition, is there or are there going to plans to update our modem to a 5g modem, or should I just save money to get the newer phone?
modem chip is integrated into main board. so, it cannot be upgraded to nr5g modem. you probably mean new model which has nr5g modem. i think nr modules are too expensive at this moment. maybe year or two, nr modules might be worth it.
nr has too sub technologies, standalone and non-standalone. current nr implementations are non-sa, which means nr frequency bands are extended into lte. some nr benefits come when standalone mode hits for wide usage.
Which newer phone? The PinePhone and the PinePhone Pro use the same 4G modem, a Quectel EG25-G. PINE64 has not released any 5G cellphone, and I am not aware of any plans to release one at this time.
What is sure that upgrading the modem if and when a 5G model will be out will require replacing at least the mainboard if not the entire phone, because the modem is soldered on the mainboard. But waiting for a 5G model does IMHO not make any sense at this time, since there are no public plans for one.
Probably nobody wants this, but shouldn't it be possible to make a battery-case-like wraparound thing with a 5G modern in it?
:wq
Most likely yes, or even a backcover replacement like the keyboard etc., or you could just plug a USB modem into the USB-C port (even the built-in modem is a USB device after all), but it will also need software support. And the speed will be limited by USB 2 speeds in all scenarios.
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,195 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 16,072 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,623 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,694 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,177 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,767 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,765 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,354 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,472 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 4,004 03-25-2025, 08:51 PM
