can't get quartz64-A working
use images from this theme. official images are now being assembled from a broken build system and will have problems.
https://forum.pine64.org/showthread.php?tid=16312
In the photo with jumpers - there is no important jumper on the connector that is closer to the edge of the board (it is signed ON/OFF_BATT ). Install a jumper on it (the contacts must be closed.
(04-19-2023, 11:44 PM)balbes150 Wrote: use images from this theme. official images are now being assembled from a broken build system and will have problems.
Just to double check, we want to jump (connect) the two pins on board that are closer to the edge?
Yes
Yes
Okay, that worked! Using one of the images from that thread + the jumper succeeded. In the interest of thoroughness, I tried the mainline Armbian image recommended for quartz64a, and that did not work. As you indicated, it looks like the mainline image is broken, unfortunately. Also in the interest of thoroughness, I tried writing the SD card with dd, and that did work.
I'm marking this thread as "solved", thanks all for helping!
(04-19-2023, 09:30 PM)jyoung Wrote: Here is an image of the jumpers, and of the uart pins attached to the appropriate gpio pin.
If you don't get output via UART, try switching the white and green lines.
Mine is black-white-purple and the colors don't necessary mean much. (Black is often GND though)
  The "Should I buy a Quartz64 right now?" flow chart CounterPillow 5 23,892 05-05-2026, 07:57 AM
Last Post: kapqa
  Quartz64 seeming died Darin755 0 2,369 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 5,284 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 4,211 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 4,506 07-13-2023, 10:36 PM
  Trustzone support for QUARTZ64 capablegh 13 24,757 04-28-2023, 01:58 AM
Last Post: NCLI
  Need a working image for Quartz64B Excalibur 23 34,063 02-24-2023, 12:11 AM
Last Post: balbes150
  Booting Quartz64 Model B Jojo120120 14 22,428 01-23-2023, 03:31 AM
  quartz64 model b 2x20 max power proj964 1 5,165 10-23-2022, 05:32 AM
Last Post: CounterPillow
  quartz64 model b 2x20 pin header proj964 1 5,235 10-23-2022, 05:21 AM
