Mobian: squeekboard .yaml location
Smile
Greetings, new PPP mobian user here!
I'd like to add a custom keyboard layout to include the Shift Button on my keyboard but I can't find where the .yaml layouts are being saved.
Documentation says ~/.local/share/squeekboard/keyboards/ but I don't see a squeekboard file. Note I don't know much.
I thought maybe squeekboard is not installed and tried to built from git. Got stuck in meson _build. I started to download all dependencies it was asking for. Then it asked for gnome so I thought I am doing something wrong here. I've disabled gnome and enabled phosh back again.
Also, I see a squeekboard file in /usr/bin but can't open it. Is that from my attempt to install it?
A thank you to all the developers.
(04-15-2023, 03:31 AM)tookmeayear Wrote: Greetings, new PPP mobian user here!
see this ...
https://world.pages.gitlab.gnome.org/Pho...orial.html
layouts are hardcoded into binaries, however you can edit your own ones and copy to local user directory.
see this ...
thank you for the response. say I got one I want to use, do I copy it somewhere then gets picked up? I read before the documentation but I couldn't find that location
"The keyboard layouts are located in the subdirectory data/keyboards/ in the .yaml files"
probably here
https://gitlab.gnome.org/World/Phosh/squ.../keyboards
and location
~/.local/share/squeekboard/keyboards/terminal/
and you do not need to reboot, just deactivate keyboard and reactivate.
(04-16-2023, 06:05 AM)zetabeta Wrote: probably here
and location
I can't find those directories on my phone. note I didn't manage to install from the git repo but I assume is already installed
Actually I've just found my answer.. "the folder should be created if doesn't exist". https://forum.pine64.org/showthread.php?tid=9633
thank you
  Experimental Mobian kernel patch for extended battery life teekay 15 15,756 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 20,022 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,375 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 8,325 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 1,960 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 4,814 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 1,946 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,633 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 1,856 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 1,990 10-14-2023, 11:57 AM
Last Post: mburns
