I have a new Pinebook Pro just received in January 2023.
All is well with it, except, it makes that Popping noise from the speakers or something, and has a high pitched sound sometimes, or often.
I'm looking in to a fix.  I opened it up, and checked the Headphone Switch and made sure the trouble shooting power connector was Unplugged, which it was.
Anyone has any fixes so far?
		April 2023 just received my first Pinebook Pro and it has the same popping problem reported by others. There is a low level buzzing most of the time as well.
		Hi, it’s not dangerous.
It seems like it happens when the soundcard/hardware initializes; nothing to worry about; mine does it too sometimes & it’s been working fine for quite awhile now (daily use).  I never tried to fix it, as it’s not loud enough to bother me.
PinePhone, Pinebook Pro & PineTab2 owner.
		You got me curious, so I had to try to reproduce it. I mainly use my PBP for work; I’m not watching  videos with it.
With some US news sites, I could hear an audible pop upon changing videos (FOX/CNN)/with Freetube nothing changing videos, but sometimes a slight click, once I closed the application.
With headphones plugged in / blue-tooth earbuds, no audible noise of any kind.
I never got any noise with / without headphones changing browser tabs with Firefox 102.10.0 ers, using the stock kernel: 6.0.0-kali5-arm64 or my my own kernel.
From my media server, .avi’s did not have any noise, but .mkv’s did emit a slight click (without a headset activated) once the application was closed (VLC/Parole).
The PBP speakers are not great, I usually just use headphones or an external blue-tooth speaker. The JBL clip works well with the PBP for an external speaker and cheap Maxell or good JBL earbuds work great too, I can’t tell you the exact model number, they aren’t printed on them, I think it’s in the wiki though.
