slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64)
#51
installation README.TXT
kernel 6.1.1
slarm64-current-aarch64-server-quartz64-6.1.1-build-20230101.img.zst
slarm64-current-aarch64-server-quartz64-6.1.1-build-20230101.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.1.1-build-20230101.img.zst
slarm64-current-aarch64-xfce-quartz64-6.1.1-build-20230101.img.zst.sha256
donation   irradium
kernel 6.2.0
slarm64-current-aarch64-core-quartz64-6.2.0-build-20230305.img.zst
slarm64-current-aarch64-core-quartz64-6.2.0-build-20230305.img.zst.sha256
slarm64-current-aarch64-server-quartz64-6.2.0-build-20230305.img.zst
slarm64-current-aarch64-server-quartz64-6.2.0-build-20230305.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.2.0-build-20230305.img.zst
slarm64-current-aarch64-xfce-quartz64-6.2.0-build-20230305.img.zst.sha256
donation   irradium
kernel 6.4.0
slarm64-current-aarch64-core-quartz64-6.4.0-build-20230627.img.zst
slarm64-current-aarch64-core-quartz64-6.4.0-build-20230627.img.zst.sha256
slarm64-current-aarch64-server-quartz64-6.4.0-build-20230627.img.zst
slarm64-current-aarch64-server-quartz64-6.4.0-build-20230627.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.4.0-build-20230627.img.zst
slarm64-current-aarch64-xfce-quartz64-6.4.0-build-20230627.img.zst.sha256
donation   irradium
kernel 6.5.0-rc2
slarm64-current-aarch64-core-quartz64-6.5.0-rc2-build-20230722.img.zst
slarm64-current-aarch64-core-quartz64-6.5.0-rc2-build-20230722.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.5.0-rc2-build-20230722.img.zst
slarm64-current-aarch64-xfce-quartz64-6.5.0-rc2-build-20230722.img.zst.sha256
donation   irradium
Thank you for the link.
I installed this on a Quartz64-B but just during the username setup script it terminated with critical temperature threshold warnings.
I had to turn it off.
(I am using a small Aluminum heat sink. no fan. The temp reached 116c )
Message from syslogd@ at Sat Jul 9 12:09:44 2022 ...
: thermal thermal_zone0: critical temperature reached (115 C), shutting down
Broadcast message from root@quartz64 (Sat Jul 9 12:09:44 2022):
Dmesg/Console output:
slarm64 GNU/Linux (ttyFIQ0)
Kernel 4.19.193 (aarch64)
quartz64 login:
quartz64 login: root
You are required to change your password immediately (administrator enforced).
New password:
BAD PASSWORD: The password fails the dictionary check - it is based on a dictionary word
New password:
Retype new password:
.....splash logo removed....
The system is going down for system halt NOW!
[ 104.994101] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.047595] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.048296] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.070896] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.104394] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.130811] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.157461] thermal thermal_zone0: critical temperature reached (115 C), shutting down
[ 105.180769] thermal thermal_zone0: critical temperature reached (115 C), shutting down
....etc etc
kernel 6.5.0-rc6
slarm64-current-aarch64-core-quartz64-6.5.0-rc6-build-20230813.img.zst
slarm64-current-aarch64-core-quartz64-6.5.0-rc6-build-20230813.img.zst.sha256
slarm64-current-aarch64-server-quartz64-6.5.0-rc6-build-20230813.img.zst
slarm64-current-aarch64-server-quartz64-6.5.0-rc6-build-20230813.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.5.0-rc6-build-20230813.img.zst
slarm64-current-aarch64-xfce-quartz64-6.5.0-rc6-build-20230813.img.zst.sha256
donation   irradium
kernel 6.6.0-rc6
slarm64-current-aarch64-core-quartz64-6.6.0-rc6-build-20231017.img.zst
slarm64-current-aarch64-core-quartz64-6.6.0-rc6-build-20231017.img.zst.sha256
slarm64-current-aarch64-server-quartz64-6.6.0-rc6-build-20231017.img.zst
slarm64-current-aarch64-server-quartz64-6.6.0-rc6-build-20231017.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-6.6.0-rc6-build-20231017.img.zst
slarm64-current-aarch64-xfce-quartz64-6.6.0-rc6-build-20231017.img.zst.sha256
[    84.895] X.Org Video Driver: 25.2 [    84.895] X.Org XInput driver : 24.4 [    84.897] (II) xfree86: Adding drm device (/dev/dri/card0) [    84.904] (II) xfree86: Adding drm device (/dev/dri/card1) [    84.976] (==) Matched modesetting as autoconfigured driver 0 [    84.976] (==) Matched fbdev as autoconfigured driver 1 [    84.976] (==) Assigned the driver to the xf86ConfigLayout [    84.981] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so [    84.990] Module class: X.Org Video Driver [    84.990] ABI class: X.Org Video Driver, version 25.2 [    84.991] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [    85.037] (II) modeset(0): using drv /dev/dri/card0 [    85.040] (II) Loading sub module "glamoregl" [    85.040] (II) LoadModule: "glamoregl" [    85.041] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so [    85.094] (II) Module glamoregl: vendor="X.Org Foundation" [    87.643] (II) modeset(0): glamor X acceleration enabled on Mali-G52 r1 (Panfrost) [    87.643] (II) modeset(0): glamor initialized [    88.174] (II) modeset(0): [DRI2] Setup complete [    88.174] (II) modeset(0): [DRI2]  DRI driver: rockchip [    88.174] (II) modeset(0): [DRI2]  VDPAU driver: rockchip [    88.178] (II) Initializing extension DRI3 [    89.295] (II) GLX: Initialized DRI2 GL provider for screen 0 [    89.295] (II) Initializing extension XFree86-DRI [    89.295] (II) Initializing extension DRI2 [    89.614] Module class: X.Org XInput Driver [    89.614] ABI class: X.Org XInput driver, version 24.4 [    89.615] (II) Using input driver 'libinput' for 'rk805 pwrkey' [  103.172] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control' [  103.239] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control' [  103.274] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
donation   irradium
  USB on Quartz64 Zero litbulb 2 3,055 11-09-2026, 01:33 PM
Last Post: elizabethtaylor
  DietPi OS for Quartz64 MichaIng 48 65,194 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,136 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,731 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 194,557 03-23-2025, 01:10 AM
Last Post: balbes150
  quartz64-a - on-board SATA port problems manning 2 6,233 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,019 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,786 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,394 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 60,775 03-17-2022, 06:29 AM
