Most stable Pinephone OS
Is there any OS that is actually working and stable? I am going down the list installing every OS but there's always a problem to be found, some more than others but none of them work enough to make the device live up to it's name - the Pine "Phone".
If anyone has had any luck with an OS please let me know. I have installed more than half the available OS's and am on the precipice of giving up.
Thanks.
Mobian is quite stable in my experience, mind that it requires Tow-Boot on the regular PinePhone however. Which issues are you experiencing? Maybe it's smarter to ask about these issues specifically, as some are more related with other factors (such as the modem firmware).
Arch Linux Phosh is a good choice. Most things work and modem and sound reasonably well.
That stated I still use a Blackberry for calls (important).
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
(11-28-2022, 11:50 AM)karcdaeh Wrote: Is there any OS that is actually working and stable? I am going down the list installing every OS but there's always a problem to be found, some more than others but none of them work enough to make the device live up to it's name - the Pine "Phone".
Thanks.
Arch Linux with Phosh - @Danct12 does a great job!
Everything works: SMS, MMS, Camera, GPS, calling, contacts, calendar, g00gle email, synchthing...
I have not tried any other OS. I have used Arch for many years on my desktop and laptop.
(11-28-2022, 02:59 PM)fxc Wrote: Mobian is quite stable in my experience, mind that it requires Tow-Boot on the regular PinePhone however. Which issues are you experiencing? Maybe it's smarter to ask about these issues specifically, as some are more related with other factors (such as the modem firmware).
The biggest issue is not being able to use the phone. I've tried the recommended providers and have had no luck. Another annoyance is that the side power button does not turn on the phone or wake it from sleep.. The only way I can get the display back on is to plug it into a usb port and then remove it. Volume buttons also do not work.
At this point I was planning on just insalling organic maps and using it as a gps for my bike but the power button doesn't work, There are other issues, but not show stoppers. Although after the last manjaro update i was unable to bring up a terminal. It would launch and then crash after a few seconds.
(11-28-2022, 05:19 PM)Chief Wrote: Arch Linux Phosh is a good choice. Most things work and modem and sound reasonably well.
I didn't try arch because it's relatively close to manjaro and i've had many problems the manjaro OS. That said,  manjaro does not equal arch so i will give it a try. I  use arch as my main OS on my desktop server.
Fingers crossed. Unfortunately I moved to colombia recently and i don't think there is a recommended provider to use here with the pinephone. There are only two main providers here though and i have sim cards for both in my two burner phones.
Thanks.
OK cool. So two positive reviews for arch. I am very familiar with it since i also use it for my desktop. Thanks.
Arch with Phosh does look good. Today I installed Arch to an SD card to test out and it seems to work really well. The only issue I noticed was Megapixels crashing, but that's Megapixels for you. I do have Mobian on the eMMC and overall that's been very good as well but there have been some issues with recent updates, so this is an alternative to boot up on when needed.
can you boot debian with the arch sd card inside ?
ezik
Another vote for Mobian, been using it for more than a year.
PinePhone, Pinebook Pro & PineTab2 owner.
  How can I record video on a Pinephone? kk22 23 18,581 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 5,735 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 6,179 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 606 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 3,623 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,064 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 871 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 5,566 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 2,147 10-06-2025, 09:05 PM
  iso pinephone for sale (USA) elwoodb25 0 4,224 09-24-2025, 09:25 PM
Last Post: elwoodb25
