Pine Phone Doesn't Recognize New MicroSD Card
I put a new MicroSD cad (class 10, 32GB bought from Pine64 a few days after i bought the phone) into the Pine Phone, executed lsblk and fdisk -l and the card isn't showing up.  The results list only mmcblk2 and zram partitions.  There should be mmcblk0.
Any response is appreciated.
(11-22-2022, 04:52 AM)_radv_ Wrote: I put a new MicroSD cad (class 10, 32GB bought from Pine64 a few days after i bought the phone) into the Pine Phone, executed lsblk and fdisk -l and the card isn't showing up.  The results list only mmcblk2 and zram partitions.  There should be mmcblk0.
Did you mount the SD card?
What OS are you using?
Things I would try:
  • Try re-seating the SD card in the slot. Make sure it goes all the way in and you have it in the correct slot (the upper slot - NOT the lower SIM slot), and you have it oriented with the contacts facing down.
  • Is this the only SD card you have? Could you try a different card to see if it's the card or the phone?
  • Do you have an SD card adapter/reader that you could plug into a computer to see if it shows up?
  • With the back off the phone, insert the SD card into the slot, but don't push it in all of the way. Insert the battery. Power on the phone. Open a terminal. Check dmesg as you push the SD card fully into the slot (use dmesg -w)
Other details that could be helpful:
  • You haven't told us if this is an Original Generation Pinephone or a Pinephone Pro
  • You haven't told us what distribution (arch, mobian, ubports....) you are using.
  • You haven't told us what desktop environment (phosh, plasma mobile, sxmo...) you are using
@mark1250 and anyone else,
It's an original generation (but new to me) with the original software: Pine64 Pine Phone 1.2, Linux version 5.11.3-1-MANJARO-ARM.
wget output implies "error 22 whilst initalising SDIO card" and "sunxi-mmc 1c0f000.mmc: no support for cards volts".
I noticed: when I took the sd card out to run wget the devise stalled when booting. I had to do a hard reset and then turn it on again.
Also, yesterday, when I turned it on with the SD card inserted the first time the time was wrong on the screen for a giid 5seconds.
I had tried a different SD card a few days ago. It worked, poorly, at first, and then stopped completely to the point I'm at now.
  Default password for KDE plasma pine phone Toni 0 8,387 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 4,811 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,306 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,356 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 6,785 09-19-2024, 03:49 AM
Last Post: jennybaso
  PinePhone - boot from microSD laserpyramid 9 10,015 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 3,071 04-02-2024, 11:50 AM
  Looking for the "non-phone" OS wakyct 7 9,199 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 12,876 03-11-2024, 10:42 PM
Last Post: Emelia525
  install iso from sd card to emmc aular 2 4,050 03-11-2024, 10:24 PM
