Gnome settings crashes in Mobian after magnification change.
I restarted my installation of Mobian on the SD card in the PinePhone Pro. It works well after a dist-upgrade on October 28, 2022.
But I changed the screen magnification in gnome settings, which resulted in gnome settings crashing on its startup. The solution is to delete the binary format file, ~/.config/dconf/user .
Thank you for your post, mburns. This bug was driving me crazy!
After daily updates as of November 24, my copy of Mobian is disabled. the console, Settings, and other applications crash.
OK now! Mobian is back in working order after an update as of 8:36am EST. But clicking on some options in Settings will crash it.
  Experimental Mobian kernel patch for extended battery life teekay 15 17,194 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,246 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,888 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,316 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,238 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,292 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,113 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,908 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 2,014 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,144 10-14-2023, 11:57 AM
Last Post: mburns
