DietPi OS for ROCK64
#41
I went through the initial update process and it did the first reboot. I was able to SSH in after the reboot but still no hdmi monitor output. I executed a shutdown, disconnected the hdmi, powered it up again and SSHed in again. But this time I waited until I had the SSH connection before connecting the hdmi and now the monitor works. I've since rebooted and hdmi is working even if plugged in.
So thank you, I'm up and running with both of my new ROCK64s.
I rarely use the hdmi, but one is for a friend that is new to SBCs and I think he needs it.
(11-14-2022, 01:50 PM)MichaIng Wrote: I just added ROCK64 to our image build script and generated new images. It's still (latest) Armbian kernel and U-Boot packages, but freshly partitioned image file + rootfs via debootstrap. Probably the more recent U-Boot works more reliable: https://dietpi.com/downloads/images/testing/
If the Bullseye image does not boot, the Bookworm one won't either, which differs only in userland.
EDIT: Ah I just saw now that you were able to SSH into the system with the old image, but no HDMI output? Also finishing first run setup, including kernel upgrade does not help with this?
EDIT2: Ah lol, here it was reported at Armbian: https://forum.armbian.com/topic/24146-th...lled-hdmi/
Do you see the same error(s) in dmesg -l emerg,alert,crit,err?
I re-downloaded and installed DietPi today 12/7/22 and it started right up. Thank you!
I want to run WordPress on this but can't get mysql-server installed. I don't want to install the mariadb-server they say 100% compatible but using this as a backup and want to copy my WordPress database to it. If I install mariadb-server I get errors.
So how can I install mysql-server?
This is on a Recon Sentinel Rock64.
Found out how to install mysql-server on it.
It the /etc/apt/sources.list
Added this one line.
deb http://ftp.de.debian.org/debian sid main
Then these commands:
apt update
apt install mysql-server
It works. It has lots of other updates but after I installed the mysql-server I put a # before that line. I am not sure if them updates will break it or not.
Thank you.
(09-01-2024, 06:43 AM)RaymondDay Wrote: I want to run WordPress on this but can't get mysql-server installed. I don't want to install the mariadb-server they say 100% compatible but using this as a backup and want to copy my WordPress database to it. If I install mariadb-server I get errors.
apt update
Thank you.
Be very careful when adding the Sid repo. The way you added it, you are practically on an unsupported developer playground now. Two years too late now Smile but for anyone landing here, create a preferences config to allow pulling MySQL packages only from Sid, but nothing else:
cat << '_EOF_' | sudo tee /etc/apt/preferences.d/mysql-sid Package: * Pin: release n=sid Pin-Priority: -1 Package: src:mysql* Pin: release n=sid Pin-Priority: 500 _EOF_
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,220 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,607 07-31-2026, 03:20 AM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,291 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,951 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,963 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,179 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,396 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,235 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 120,520 09-01-2024, 06:05 AM
Last Post: RaymondDay
  Rock64 v2 - did not work song / audio sqw200zu 2 6,713 03-14-2024, 03:09 AM
