Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue
A thread with similar issue is closed.
postmarketOS is not charging the batteries at times; and the menu bar shows always charging, regardless if the device is plugged or not.
Also, the same result I can see from 'powersupply' package, always charging.
This issue happened with the newest stable release.  I have attempted replacing the battery with J7, and the same issue is there.
When PinePhone Pro is booted with Manjaro Plasma stable OS, the battery issues is not there, with both the PinePhone OEM battery, and the J7 battery.
With Manjaro Plasma stable OS, if I disconnect the phone from the charger, it shows so; and if I plug back the USB charging cable, the PinePhone Pro will charge, with no issue.
It is indifferently an issue with postmarketOS with charging the phone; or thinking it is being charged and connected (while it is not).
Issue is not with the hardware, it is with postmarketOS.
I have to boot up the Pinephone Pro with Manjaro Plasma OS to get the phone charging, and not depleting the battery, then switch back to postmarketOS. The loveliness of dual boot setup (SD card & eMMC).
Please, if any command I need to run, to supply more details, I am more than willing to do so.
Thank you
Is it this issue?: https://forum.pine64.org/showthread.php?tid=17740
Quote:To see if you need this fix, go into your Power settings and see how many batteries it displays. You'll probably see up to 4 of them. Unless you have the PinePhone keyboard connected, it's likely only one of them will show greater than 0% charge. This one is the actual charge level of your PinePhone's battery. The others seem to be little more than red herrings that confuse UPower!
If the displayed level of charge on the top tray is much lower than the one visible on the Power settings (If 4 batteries are shown, it may be exactly a quarter of it), and your distro isn't more than about 6 months old, then you most likely need the fix. If the two charge levels match up then you're all good.
The linked issue can affect charging because it makes the OS think the phone has a lot less charge than it really does, so it can show it's forever charging (but never getting near 100%) even though the battery is really full. It will also shut the phone down when the battery isn't really empty, because it thinks it's empty.
Your issue with it showing that it's charging when it's unplugged sounds like something different though.
  Freezing and force rebooting on PinePhone HHawks 4 4,689 05-02-2025, 09:04 AM
Last Post: HHawks
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,631 11-18-2024, 02:23 AM
Last Post: linmob
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,824 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 13,239 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Issues after installing latest PostMarket OS with POSH xen314 4 8,019 08-20-2023, 11:18 PM
Last Post: xen314
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,312 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  Battery issues user641 3 6,496 07-17-2023, 10:43 AM
Last Post: alaraajavamma
  installed postmarketos v23.06 no audio samlo 1 4,440 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 3,953 07-01-2023, 08:16 AM
Last Post: AndyM
  VPN for PostmarketOS publiclewdness 1 4,979 03-11-2023, 04:35 PM
