Does pinephone allow you to repair your own device as easily as fairphone?
Hey guys,
I was wondering if the pinephone allows you to repair your own phone as easily as fairphone?
https://www.fairphone.com/en/
Does pinephone have like this modular approach where if for example your camera is broken you can easily replace the camera with a replacement part yourself without needing a technician?
(10-02-2022, 10:09 PM)unix21311 Wrote: Hey guys,
i think it is yes and no. pinephone is quite easy to open and it doesn't use weird screw. but it's not that modular, some components are replaceable, but mainboard practically have to be replaced as one.
https://pine64.com/product-category/pine...are-parts/ . camera modules seems to be available, but shipping fees might be annoying. pinephone regular and pp pro components are not compatible to each other.
I see mate, thanks mate Smile
But one thing, would pinephone consider making it as modular as fairphone in the next update, can I request for this?
Ithink it is yes and no
  Zig booting up on PinePhone WhiteHexagon 0 3,483 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 3,841 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 5,926 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  Second-Hand PinePhone rdv 9 8,088 01-05-2025, 11:42 PM
  pinephone 3 ideas aular 5 6,725 11-08-2024, 06:35 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 4,149 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 4,870 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 6,208 12-09-2023, 01:26 AM
Last Post: crocspot
  can i install mobian on pinephone? luofeiyu 2 4,009 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 10,187 10-03-2022, 05:53 AM
Last Post: unix21311
