RockPro64 Stopped working
I have a rockpro64 that went tits up. I read that Armbian should be tried to see if the hardware is any good. I can't get armbian to boot. When it installs I see an error among all the text "direct firmware load for rockchip/dptx.bin failed with error -2", so I presume the HW has failed?
Have you tried something other than armbian? Nothing about that error message says hardware failure to me.
There are official Debian images from Debian themselves, I recommend you try those.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(11-01-2022, 02:20 PM)CounterPillow Wrote: Have you tried something other than armbian? Nothing about that error message says hardware failure to me.
I have only tried: Armbian_5.75_Rockpro64_Debian_stretch_default_4.4.174_desktop
It takes a long time to do it's initial install because of all the timeouts, one presumes. When it finishes it powers off.
That seems like quite an old image based on a BSP kernel. Please try a mainline kernel based one: https://deb.debian.org/debian/dists/bull...rd-images/
See https://wiki.pine64.org/wiki/ROCKPro64_S..._Installer for instructions and the troubleshooting link regarding GPU.
In general, you do not need to use BSP kernels anymore for ROCKPro64.
Plebian GNU/Linux
I don't know what that means.
I downloaded the Rock64pro image from the site you suggested.
It fails too. As it tries to retrieve a file, it fails with a "Recount try exceeded" and then moves on to the next file which fails the same way. Eventually you get a script error and => as the last characters
I had a wireless keyboard dongle plugged in on the first test, but not the second.
Same error pattern from each test.
Is this using the eMMC or using a  SD card? I've had varied success with Armbian images on various RK3399 boards (listed as supported). I can at least confirm that FreeBSD's 13.1-RELEASE image booting off a SD card works fine (you might run into boot issues you have a 4K monitor connected however). Serial is set to primary boot console so you'll only see partial output of the boot processing using a monitor.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,839 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,525 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,856 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,599 11-26-2024, 11:08 AM
  power button not working Vista8720 0 3,486 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,810 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,327 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,986 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 14,067 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,276 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
