Decent Pinebook Pro barrel PSU / Charger
As it might help...
This is a decent 5V 4A barrel charger for the Pinebook Pro (European plug) that is much better than the original piece of crap :
https://www.amazon.fr/gp/product/B07L63Q66R/
At least I now can use the Pinebook Pro and get it to charge simultaneously, with a decent length cable as well.
(My original provided crappy “charger” died on me after less than a month...)
Have done the same here in the U.S. Original charger's plug fell apart in the first few uses.
 while(!(succeed=try()));
Bought a dell usb-c charger, clueless about where I left the original charger ;-)
I'm 2 months with the original charger that you can swap out plugs with and no issues. I bought the dock & use a powered USB hub for external hard-drives. The original PinePhone USB-C docking bar (in the convergence kit) also works with the PBP.
PinePhone, Pinebook Pro & PineTab2 owner.
  Replacement battery for PineBook Pro DrYak 5 7,143 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 8,297 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,812 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 4,381 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,853 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,822 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,276 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 216,179 09-13-2023, 03:43 AM
Last Post: k3dAR
  Sanity check on spliced charger jcun4128 12 9,827 05-10-2023, 05:23 AM
  PineBook Pro dead ottahe 9 13,879 01-18-2023, 07:41 PM
Last Post: ottahe
