Battery
Is the battery the same as the original pinephone ? Or will the pine charger work for the pro battery. And is there a place I can buy extra batteries.
I think you should ask that in the PinePhone Pro section.
This is the Pinebook Pro section.
  Pinebook Pro drains ny battery after shutting it off Tongman 4 7,103 12-01-2022, 02:50 AM
  Pinebook Pro freezes when running on battery petaramesh 5 7,744 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 7,016 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 11,064 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 10,568 02-10-2022, 11:52 AM
  NVMe SSD and battery life? dieselnutjob 3 7,390 04-19-2021, 01:55 PM
Last Post: slyecho
  [AUG 2020] PBP Battery Issue (?) mercato 7 13,475 09-22-2020, 12:10 AM
  No battery or wifi after poweroff Goin2mars 3 7,804 09-19-2020, 09:58 AM
Last Post: xmixahlx
  Battery draining with external power while under load? RndmNmbr 17 32,499 06-24-2020, 08:33 PM
Last Post: Syonyk
  Battery not charging via AC Adapter laissezfarrell 1 5,502 05-30-2020, 06:05 PM
