Bootloader: SD card boot quirks
I am currently running Tow-Boot but I noticed similar behavior with U-Boot:
- If I reboot, and try to select boot from SD - it fails, sometimes it freezes or fails to detect the linux image
- If I power cycle - most of the times I can boot from SD.
With U-boot it was similar, after a reboot, only boot from emmc was possible. But if I powered off/on, it would boot from SD.
Is this intended behavior?
I also use Tow-Boot.
I have noticed some inconsistent behavior with SD booting as well. When I attempt to boot from SD and the card was reimaged and never had been booted from, I will sometimes get an issue where the display flashes static white and black in an occasional strobe.
I have seen consistency once I have successfully booted once from the SD card and have not removed or replaced it, though.
  Boot Order in Pinebook Pro food 12 19,084 05-25-2026, 08:28 AM
Last Post: finmark
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,100 03-10-2025, 01:55 PM
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,640 08-21-2024, 04:17 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,581 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,438 08-21-2023, 09:08 PM
Last Post: vanessadonald
  2TB SD Card Write Errors jiacovelli 3 4,386 06-02-2023, 06:13 PM
  Emergency Mode Boot Hotkey? jiacovelli 20 20,252 06-02-2023, 01:32 PM
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 4,351 03-24-2023, 04:25 PM
Last Post: srs5694
  Tow Boot install help Paulie420 7 11,393 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,064 10-31-2022, 10:14 AM
