Android 12 L Quartz64 and Quartz64pro
Ah ok
Fixed google login no magisk and modules etc
Fixed settings --user 0 put secure user_setup_complete 1
Fixed volume control and set to 40 default 15
4K Hdr audio-passthrough etc .
add google account , try youtube login , update youtube first ,then start youtube Smile , after that update the rest of the packages.
smartube has a bug when youbue has account smartube cant play , and netflix i think Sad
sd/emmc img for etcher , dd etc
https://drive.google.com/file/d/1YJLaRqn...sp=sharing
OK sorry I thought I replied. This emmc install was much smoother and worked out of the box. The volume of 40 probably too high since by about 25 it is muted, that is why I used 15 in my testing. I didn't install Google, just a custom PVR app I use.
Martin
(08-19-2022, 01:07 PM)emveepee Wrote: OK sorry I thought I replied.  This emmc install was much smoother and worked out of the box.  The volume of 40 probably too high since by about 25 it is muted, that is why I used 15 in my testing.  I didn't install Google, just a custom PVR app I use.
Martin
Thnx
ow you can unmute it , it was just a setting
got also a 5.10 but that has some video playback issue with youtube ,in kodi and other players it works well
i post them this week .
Well someone has to try to update the android Smile
GoogleTV 12.1 r08 RKR10
build from the khadas android sources
Build a Quartz64-A with SATA1 enabled usb3 is disabled
4.19 kernel
ddr and cpu settings same as rk3568
configured settings for external devices
fe310000.sdhci
fc400000.sata
fe260000.pcie
fd880000.usb
fd800000.usb
fe2b0000.dwmmc
fc800000.sata
usbhost/fd000000.dwc3/xhci-hcd.5.auto
3c0800000.pcie
3c0000000.pcie
fe330000.nandc
and for the QP64 rk3588-evb1-lp4-v10 not tested
5.10 kernel
#sdmmc: mmc@fe2c0000
#sdhci: mmc@fe2e0000
#sata2: sata@fe230000
#sata0: sata@fe210000
#usb0 usb@fc800000
#usb1 usb@fc880000
removed most RK-apps
Spoofed as ADT3
Default 4K ui
Enabled Games with pixelproputils
* Free Fire - unlocked 90 FPS
* COD Mobile - unlocked 120 FPS (only on multiplayer mode)
* PUBG Mobile - unlocked 90 FPS
* Wild Rift - unlocked 120 FPS
* Cyber Hunter - unlock 90 FPS
* Fortnite - unlocked 90 FPS
* Mobile Legends - unlocked 90 FPS
Appdrawer to access non tv-apps
Chrome webrowser
Root
Login with lan add google account
with wifi/Bt add account through phone
wifi,BT, Mic ,Camera enabled by default disable if no use in settings
And a lot of settings for sound and video
extra for RK3588 AI
#flash
gpt-full.img
for all on 1 device
SD/EMMC
#flash
gpt-external.img
on the external device USB/SATA/NVME/SD/EMMC
#flash
the boot part for external
gpt-min.img (SD/EMMC) or min_update.img (EMMC)
RK3588 EVB1-LP4-V10 (not tested
https://drive.google.com/file/d/1A4v7CNd...sp=sharing
RK3566 Quartz64-A
https://drive.google.com/file/d/1xei3SUO...sp=sharing
  Android source code repository MichaIng 1 1,150 07-28-2026, 08:06 PM
  Android on SOQuartz alistson 2 15,088 10-29-2024, 01:27 PM
  Android 12.1 Kernel 5.10 Quartz64-a shaggy013 2 7,988 12-08-2022, 06:52 PM
Last Post: shaggy013
  Android SDK Build. west0330 1 4,394 12-01-2022, 10:55 AM
Photo Android 11 ATV shaggy013 2 7,390 05-20-2022, 03:25 PM
  Android 11 4k HDR shaggy013 6 10,819 05-17-2022, 10:10 AM
Big Grin Android 12 Tablet , Box/Atv shaggy013 3 8,393 05-17-2022, 09:19 AM
  Can't compile Android 11 from SDK dieselnutjob 8 16,857 02-17-2022, 08:53 AM
Last Post: Firesped
  Android SDK download keaton 2 7,633 11-23-2021, 03:20 PM
Last Post: keaton
