i2c-bus kernel modules
(06-03-2016, 03:37 PM)robertvaldimarsson Wrote: [SOLVED] i now get my i2c device detected, and have no idea why Big Grin
i did a re-setup of debian from scratch. i must have broken something along the way Sad
thank you very much for your patience and help martinayotte
i'm curious if you had the i2c device connected during the recent setup ?
The presence of i2c devices isn't required during setup.
Maybe Robert got some other issues, such bad kernel image.
No, it actually wasnt connected. I also can connect a i2c device to a running system and it will be instantly recognized now (although that is probably not recommended).
Robert, I presume you didn't figured out what was the differences between before and after you upgrade.
it would be interesting to know if someone else face the same issue.
(06-03-2016, 08:13 PM)martinayotte Wrote: Robert, I presume you didn't figured out what was the differences between before and after you upgrade.
my colleague recently bought Arduino and played with some simple circuit. He got some under voltage issue.
During the troubleshooting he found out that 1 ribbon wire was not connected correctly to the bread board.
Perhaps this was the issue here as well.
Hi, sorry for the late reply.
Unfortunately i couldn't figure it out, since i overwrote the SD card. But it coul well be that I screwed the image up somehow. There were several problems, that made me go into the config files. I was pretty sure I haven't touched anything i2c related, but maybe i accidentally did. It is very unstatisfying not to know the reason, but the new image worked out of the box.
Generally, i think the images on pine64.pro are more up to date, than the ones on the wiki, but that might just be my impression, and should be irrelevant, since i updated the kernel every time.
It was not an connection issue, since I used the same cables both times, but you are right, that is generally something to look out for.
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 671,072 05-21-2018, 06:30 AM
Last Post: Luke
  how to set kernel parameter 'fsck.mode=force' marcelser 6 21,011 05-09-2018, 09:07 PM
Last Post: pfeerick
Question Debian Jessie with 4.x.y kernel and complete hardware support? Spark 2 8,817 04-24-2017, 09:56 PM
Last Post: Spark
  Adding a missing kernel module spz2k 8 18,779 01-10-2017, 06:22 AM
Last Post: xalius
  NIC not visible after kernel update xleon 1 5,311 11-15-2016, 05:23 PM
Last Post: xleon
  [OUTDATED] Debian Jessie (4.7.0-rc1 Kernel) Images fire219 4 22,747 07-20-2016, 02:36 PM
Last Post: umiddelb
  How to install modules into system? MicroDiery 6 13,433 05-27-2016, 06:44 PM
Last Post: JamesHarris
  Debian kernel upgrade question jl_678 2 7,505 04-18-2016, 05:54 PM
Last Post: jl_678
