PBP booting but stops at flashing power led
I just received my new pinebook pro in 08/2022. After installing the ARM Manjaro Gnome desktop OS to eMMC booting from Manjaro SD card, the PBP started with the new OS. After a couple of system starts, the PBP booted showing the u-boot screen, then showed a blinking cursor in the upper left corner and just stopped with a green-orange-blinking power LED. This has not changed since then. The following paragraphs describe my attempts to fix the problem.
I tried booting from SD card (the same card that worked before) but it doesn't work anymore. I tried different Linux distros to create a bootable SD card using Balena Etcher, e.g. Manjaro Gnome/xfce/KDE and Armbian (new and older versions).
After that, I opened the back cover to check the eMMC switch (no. 24 regarding the PBP wiki). But the new PBP does not have the switch as described. There is another switch (turned by 90 degrees to the original one) which is covered/sealed by a transparent material. I compared the switch to my other PBP (2020 model) and it looks different in my new PBP.
Using a USB eMMC adapter, I flashed several Manjaro and Armbian linux distros on the eMMC and inserted it back into the PBP. My PBP does not boot anymore: not with the eMMC and not with a bootable SD card.
When I insert the eMMC of my old PBP, the PBP boots to an older Manjaro KDE plasma. Keeping the old eMMC in the PBP, I tried to boot from SD card to flash a newer distro to the old eMMC. But it did not work. The PBP only starts from the old eMMC and not from any inserted bootable SD card. The problem with the old eMMC is that wifi is not working (not showing any networks). I do not dare flashing the old eMMC using the USB eMMC adapter...
Is it possible that the new eMMC has a failure and how can I check?
I read a lot of threads in the forum, on reddit and other web sources but all described steps and tips did not work for me. Is there a better way to flash a linux distro with u-boot etc. to eMMC? I also read that it is possible to boot the PBP without eMMC. That does not work with my PBP. Has this changed with the new model? I highly appreciate any tips and hints on how to proceed with my new PBP.
Maybe you mean the login screen? Most (nearly all) uboots only display over serial
I think you need a "hard reset", the button inside OR hold pwr button for 20+ seconds
(since pbp has a battery, if it gets into a 'bad state' it can remember that state)
Maybe the uboot on emmc (which has priority) is defective OR maybe some video mismatch
The blinking leds suggest a uboot problem
I suggest leaving emmc out until you get a reliable boot, then you always have a 'fall back"
wifi firmware,, since it seemed to work OK, I am still on the 1st firmware version, that is, I pinned it
(late 2019) For some reason, when the update in 2020 came out, it only helped some people, not all
Not clear what is right or wrong
Thank you for your immediate response and help!
May be, I used the wrong "name" for the boot info screen. Here is a photo of the screen before it goes black with the blinking cursor and then flashing orange-green power LED.
I pressed the internal reset button many times and also pressed the power button for 20+ seconds. That did not change the PBP behavior.
I share your assumption that the uboot on the eMMC is the problem. Unfortunately, after removing the eMMC the PBP does not even boot. THe power LED stays off during boot without eMMC. In one thread I read that the LED is switched on via software (not hard-wired) during uboot. From this, I assume that the SD card's uboot is not executed when the eMMC is removed. Does removing the eMMC require to switch off the eMMC card using the switch no. 24? If yes, then please help me withe the new board layout. It changed compared to the PBP version in 2020. With the new PBP, the switch is not available as described in the wiki tutorials.
Regarding the wifi: running the 2022 PBP with the old eMMC, does not detect/recognize the wifi card. There are no settings for wifi available. Thus, it seems that the old Manjaro KDE Plasma OS does not detect wifi at all in the new PBP. I will try to update the old eMMC to the latest Manjaro KDE Plasma using the old PBP. Unfortunately, my old PBP freezes after 10-15 minutes of using it. I could never fix this issue with the 2020 PBP. My hope was to have a new working PBP and then replacing parts step-by-step to identify the problem with my old PBP. If the PBP does not freeze too early, the old eMMC will be updated and I can use the newest distro to run in the new PBP. May this solves the wifi issue.
Still, I like your suggestion to first get the new PBP running without eMMC. Do you know any steps to follow? Right now, the PBP does not event switch on the power LED when I remove the eMMC.
You are right, that is a uboot screen
Why it won't boot from SD seems very strange, if there is no uboot at all no led will turn on,
but since you have tried a few images on SD this can't be right
(nearly always an image also has a uboot in 1st 16M)
Try mrfixit image, that has a BSP style uboot
If it doesn't work on SD (with emmc out), try it on emmc
Since you know old emmc has an OK uboot copy the 1st 16M to say usb stick
(dd if=/dev/emmc of=/mnt/usb/1st-16 bs=1M count=16)
Then, with new emmc in adapter copy mbr (1st sector,,count=1 bs=512) somewhere
write 1st-16 (from usb) to new emmc, then saved mbr.. Then new emmc should boot
Also,, there are, not so expensive, usb ->ethernet dongles.. usb2 =<$10, usb3 =$15-25
On occasion quite usefull
Thanks for the different options. I will execute all of them as soon as possible and report the results.
This is what I did and the results:
Booting from SD card
  1. Flashed Manjaro ARM xfce 22.06 image to SD card using Balena Etcher
  2. Flashed idbloader, uboot und trust images (from Github) using the "dd" commands given in the MrFixit2001 update script
  3. Reomved the eMMC
  4. Success - the PBP booted from SD card
Booting from eMMC
  1. Saved the first 16M from the old eMMC
  2. Saved the first 512B from the new eMMC (the mbr)
  3. Flashed the first 16M to the new eMMC
  4. Flashed the mbr back to the new eMMC
  5. Booted the PBP and got the same result: power LED flashing green-orange
Thus, I can boot from SD card (but not with eMMC inserted - only without eMMC) but not from eMMC. Before I posted my issue, I also tried to backup the old eMMC and flash the image to the new eMMC. During the flash process I got an error that the size does not fit.
Is there something else I can do to properly flash the new eMMC?
I also tried the following:
a) Flashing Manjaro ARM xfce 22.06 image to eMMC
b) Same as a) and updating idbloader, uboot and trust with MrFixit
c) all steps from a) and b) and flashing the mbr
Unfortunately, the result is the same as described before: boot screen => blinking cursor => power LED flashing green-orange.
My guess is that uboot is finishing, the OS (manjaro xfce ??) has a bad dtb (or maybe initrd)
To really know you have to see a serial output from uboot
Use gparted to shrink old emmc a few GB, whatever appropriate
With unallocated space it doesn't matter if there is a slight size mismatch
When I shrink the linux os partition and flash the stored image from the old PBP emmc, I get the following error mesage:
Error writing 1048576 bytes to offset 27577548800: Input/output error (g-io-error-quark, 0)
Actually, I get the same error message (with different nos) whenever I try to flash to this partition on the new eMMC.
That error suggest to me that the flash is bad
If the offset is bytes, that is 25.68 GB
So, as an experiment, partition the emmc with a partition at 24 GB, 4GB long
see if this can be written to and read, fat 32 fs, copy a big enough zip, then test it
(zips are very sensitive to errors)
I did as you suggested: copied zip files to a partition around 24-26GB. No errors were thrown.
After that, I again flashed Manjaro ARM xfce 22.06 for PBP to the eMMC using Gnome Disks. Then, I flashed the previously saved partition 2 of the old working eMMC to partition 2 of the new eMMC. The saved .img file has 50.3 GB and partition 2 of the new eMMC has 62 GB.
I did this five times and every time the flash process stopped with the following error:
Error writing 1048576 bytes to offset x: Input/output error (g-io-error-quark, 0)
attempt 1: offset = 39154876416
attempt 2: offset = 37957402262
attempt 3: offset = 33597423616
attempt 4: offset = 32544653312
attempt 5: offset = 32437698560
Thus, flashing the partition 2 image of the old (working) eMMC is somehow not possible. But copying zip files is working fine.
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,012 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 34,332 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 29,742 11-13-2022, 06:10 PM
Last Post: pineymousepad
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 3,014 08-12-2022, 06:41 AM
Last Post: JessicaQ
  Blinking red light for charger, no power-on bifo 11 32,778 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 3,557 11-29-2021, 01:55 PM
Last Post: stozi
  pinebook pro trackpad randomly stops working chewie 5 11,050 08-10-2021, 04:33 PM
Last Post: chewie
  Motherboard malfunction - a possible warning about power supplies mjc 8 15,280 07-28-2021, 01:04 PM
Last Post: mjc
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,639 07-09-2021, 08:45 PM
Last Post: moonwalkers
Question UK Power Supply User 11436 11 28,083 02-09-2021, 12:30 PM
Last Post: dieselnutjob
