Pinephone pro doesn't boot up anymore
Sad
Good morning,
I tried to install mobian on emmc but I hadn't changed the bootloader, from that moment the phone doesn't turn on anymore.
I tried with sd card inserted, without sd card and holding down the RE button.
I tried to connect the phone to the PC but not with the lsusb command it never appears.
Is there any way to fix the phone? spare parts?
The Pinephone Pro is a beautiful project that I would like to learn more about.
Thanks for your attention,
Giacomo
You can follow the procedures here. Or else a Mobian installation can be complemented or saved by installing Tow-boot.
https://wiki.pine64.org/wiki/PinePhone_P..._corrupted
(08-09-2022, 04:22 PM)mburns Wrote: You can follow the procedures here. Or else a Mobian installation can be complemented or saved by installing Tow-boot.
Thanks for the reply,
I tried to rewrite a microsd with a fresh mobian image but the phone never showed any signs of life.
Anyway thanks to the attempts made on your advice, I now see this command line output:
Bus 003 Device 010: ID 2207: 330c Fuzhou Rockchip Electronics Company RK3399 in Mask ROM mode
I've done some research but don't know how to continue from here.
any suggestions?
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 3,191 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 773 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 2,563 01-24-2026, 01:01 PM
Last Post: heocb
  no SD boot on replacement PPpro board, loads CN android biketool 1 1,323 11-30-2025, 07:46 AM
Exclamation Pinephone pro stuck while booting Supervisor 3 4,032 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 14,660 08-18-2025, 04:12 AM
  touchscreeh doesn't accept input henrythemouse 8 6,462 07-17-2025, 08:16 PM
Last Post: henrythemouse
  Pinephone pro packet injection for internal wifi chipset covar 3 6,686 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,786 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 14,863 02-28-2025, 07:03 AM
Last Post: tensa1000
