Android 12 L Quartz64 and Quartz64pro
for the android users
Android 12L for quartz64-a and quartzpro64
working
magisk installed
hdmi (4k ,hdr,hlg,dobly vison)
wifi
bluetooth
cec
lan
npu
for the Quartzpro64
https://drive.google.com/file/d/1zttd-9b...sp=sharing
for the Quartz64-a
https://drive.google.com/file/d/1Xg1dJOR...sp=sharing
to make a google account
add the redfin module with magisk
https://drive.google.com/file/d/16ThYgxH...sp=sharing
have fun
I'm new to this device (QP64), can you please explain how do I upload this? I've figured I can do `fastboot` to target, but I'm afraid of bricking the eMMC. Is it a raw image that I could `dd`? Can I boot device from micro SD card?
I used Etcher to burn to SDCard and also emmc directly without any installation issue. The volume is far too low for Kodi or via ExoPlayer though and I couldn't find an adb command to make it listenable.
Martin
On QuartzPro64 there are physical buttons for volume up/down that I've verified work with default Android image. You can send such keys with `adb shell input keyevent 24` for volume up and 25 for volume down.
I can lower it but I cannot raise it to a listenable level.
Martin
(07-21-2022, 05:12 AM)janisozaur Wrote: On QuartzPro64 there are physical buttons for volume up/down that I've verified work with default Android image. You can send such keys with `adb shell input keyevent 24` for volume up and 25 for volume down.
I dont have the QP64  Cry board so i can't test it
i used the default evb dts for compilation and the default box configuration
but i think where to find that to solve it
and nice to hear that it works on the qp64 Smile
(07-20-2022, 06:21 PM)emveepee Wrote: I used Etcher to burn to SDCard and also emmc directly without any installation issue.  The volume is far too low for Kodi or via ExoPlayer though and I couldn't find an adb command to make it listenable.
Martin
wich device Smile
yeah i noticed it with , if you have a airmouse disable sound and on the right side of screen apears a slider you can change the volume it is some build.prop setting
(07-20-2022, 07:34 AM)janisozaur Wrote: I'm new to this device (QP64), can you please explain how do I upload this? I've figured I can do `fastboot` to target, but I'm afraid of bricking the eMMC. Is it a raw image that I could `dd`? Can I boot device from micro SD card?
you can flash the update.img with rockchip update tools  be warned it writes default to mmc !!!
and the gpt.img you can flash with dd or balena etcher etc on a sd ,mmc, usb
i added some boot devices
PRODUCT_BOOT_DEVICE := fe2e0000.mmc,fe2c0000.mmc,fe230000.sata,fe210000.sata,fc800000.usb,fc880000.usb
(07-21-2022, 09:54 AM)shaggy013 Wrote: wich device Smile
Quartiz64a with a USB RF HID mouse/keyboard. The volume keys on this remote don't pop up the normal Android volume slider or menu. I don't see any option to disable sound, just surround formats.
Edit: I notice in my PVR client app that the Home key wasn't working either and saw this in logcat
/WindowManager: Not starting activity because user setup is in progress:
So I ran this settings --user 0 put secure user_setup_complete 1
and Home worked. Volume Up/Down still didn't but mute activated the volume dialog where I was able to raise to max volume to 15. In settings system list I see
volume_music_0x40000000=15
volume_music_hdmi=15
volume_music_headset=15
volume_music_speaker=15
Thnx for the input Smile
i solved some of the issues like volume etc
the settings --user 0 put secure user_setup_complete 1 is little troublesome , setupwizard sets that parameter only setupwizard isnt included due loop issues i have with it .
i tried several things but no succes yet to build it in Sad
lot of info for mobile only for tv is little harder due some other packages .
here you can try https://drive.google.com/file/d/1qt9y24Y...sp=sharing
(08-06-2022, 05:07 AM)shaggy013 Wrote: here you can try https://drive.google.com/file/d/1qt9y24Y...sp=sharing
Sorry I don't know how to apply that update.
Martin
  Android source code repository MichaIng 1 809 07-28-2026, 08:06 PM
  Android on SOQuartz alistson 2 14,811 10-29-2024, 01:27 PM
  Android 12.1 Kernel 5.10 Quartz64-a shaggy013 2 7,759 12-08-2022, 06:52 PM
Last Post: shaggy013
  Android SDK Build. west0330 1 4,196 12-01-2022, 10:55 AM
Photo Android 11 ATV shaggy013 2 7,097 05-20-2022, 03:25 PM
  Android 11 4k HDR shaggy013 6 10,445 05-17-2022, 10:10 AM
Big Grin Android 12 Tablet , Box/Atv shaggy013 3 8,084 05-17-2022, 09:19 AM
  Can't compile Android 11 from SDK dieselnutjob 8 16,339 02-17-2022, 08:53 AM
Last Post: Firesped
  Android SDK download keaton 2 7,378 11-23-2021, 03:20 PM
Last Post: keaton
