Audio sinks disappeared
After having a call all of the audio sinks disappeared (pactl list sinks only outputs a dummy sink) and they don't come back after rebooting (tried 5 times so far). I tried both pipewire and pulseaudio both don't show any sinks. So i assume that it's a driver issue. I also found this gitlab issue for Mobian (i run Mobian bookworm) which contains pretty much the issue i'm having with the difference that a reboot does not solve it.
In dmesg i found the following which seems to be related although i didn't look into dmesg before this problem appeared
(rt5640 is the driver for the ALC5640 I2S audio interface if i'm not mistaken)
[   44.489276] rt5640 1-001c: Failed to set DMIC clock [   44.489743] rt5640 1-001c: ASoC: PRE_PMU: DMIC CLK event failed: -22
Any help would be appreciated.
Ok after taking a deeper look into the ALSA configuration it turned out that for some reason there was a missing " inside of the /usr/share/alsa/ucm2/Pine64/PinePhonePro/VoiceCall.conf file. (i would be intruiged to know why it was suddenly missing, maybe my cheapo sd card is dying)
Also the dmesg error is unrelated as DMIC clock is the Digital Microphone clock (havent looked into the schematics if it is even used)
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 64,054 10-13-2025, 07:46 AM
Last Post: Habbytm
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 4,704 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 2,630 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 9,521 10-25-2022, 08:40 PM
Last Post: apink
  Audio Stuttering Issue SteveDog 0 2,661 10-17-2022, 12:27 PM
Last Post: SteveDog
  Suspend audio issue kmsgli 4 7,204 08-03-2022, 04:11 PM
Last Post: Subsentient
