New keyboard issue
I took the lazy man's route while real wizards figure out the Mobian fix: I installed the OpenSuSE Phosh distribution to my eMMC drive. The keyboard works fine plus the Fn key + F1...F10 keys produce the expected special characters.
sandspur
lesser wizard
Just as a data point, I continue running the target-installed from unstable 5.17 (lazy illusionist approach I guess, less work than flashing a full system), and I do not miss anything or see any showstopper bugs (caveat: I do not use the modem at all)
I guess it is slightly more work to do now that apparently the signing key for the repository has expired (or so apt tells me)…
(06-24-2022, 04:00 AM)zltpxqhp69o2 Wrote: Just as a data point, I continue running the target-installed from unstable 5.17 (lazy illusionist approach I guess, less work than flashing a full system), and I do not miss anything or see any showstopper bugs (caveat: I do not use the modem at all)
You mean this signing key issue? https://forum.pine64.org/showthread.php?tid=16856
Yes, exactly. Thanks for linking the discussion!
(06-24-2022, 11:59 AM)zltpxqhp69o2 Wrote: Yes, exactly. Thanks for linking the discussion!
I tried my PinePhone Pro in the case and it worked after a fashion. However, it appears that contact with the pogo pins is intermittent at best as it does odd things and the PPP keeps losing contact with the keyboard. I assume that the PPP Mobian must be on the unstable branch and hence have an unborked kernel as it is running 5.17.
The keyboard is working again with the latest update. The fn/symbol keys don't initially work, but can be fixed with the information at: https://wiki.mobian-project.org/doku.php...ccessories
If using the alternate version of automatic settings (keyboard-external.sh) replace in line 4: kb151 with pinephone-keyboard
(07-01-2022, 08:03 AM)Brother Cadfael Wrote: The keyboard is working again with the latest update.  The fn/symbol keys don't initially work, but can be fixed with the information at: https://wiki.mobian-project.org/doku.php...ccessories
Thanks for the information! It will be great to have my keyboard working again.
(07-01-2022, 09:14 AM)Brother Cadfael Wrote: If using the alternate version of automatic settings (keyboard-external.sh) replace in line 4: kb151 with pinephone-keyboard
Is this in relation to getting the top row Fn keys working?
It's to disable the onscreen keyboard on startup (and change display scaling.) The name got changed, so unless you replace "kb151" with "pinephone-keyboard" it won't work. ...the keyboard will still work, but the onscreen keyboard will still pop up. I don't know if the first method of "automatic settings" still works.
Farther down on the accessories page is the section for the symbol and fn keys. The symbol keys (things like - _ +) on the number keys don't work unless you create/edit the file /etc/systemd/system/phosh.service.d/override.conf The symbol keys are working for me, but I don't know a quick way to test the Fn keys.
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 729 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 9,285 12-23-2025, 04:25 AM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,905 01-15-2025, 08:08 PM
  icon keyboard chris_02 4 5,399 01-14-2025, 02:49 AM
  Keyboard not popping up on QT apps 3x5co 1 3,038 02-08-2024, 11:45 PM
  Keyboard keeps disappearing the moment it's touched jojuma 1 2,740 10-29-2023, 08:34 AM
Last Post: walter1950
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 3,549 07-17-2023, 01:49 AM
Last Post: junelung
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 3,801 07-07-2023, 03:29 AM
Last Post: jojuma
  Battery problem with a Pinephone keyboard and Mobian elode 2 5,228 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 7,376 11-28-2022, 10:58 AM
Last Post: 3x5co
