Physical keyboard symbols not working again
Back when the keyboard came out, there were some hoops to jump through to get access to all of the symbols using, such as £-+, etc.
Eventually it was fixed properly, but now it seems that recent kernels have broken it again.  There are fixes for other OSes (Mobian, Arch), but I can't find anything for PMOS.  I'd be happy just to downgrade the kernel for now, but I can't find any instructions for that.
Anyone else encountered this, and solved it?
Using PMOS +Phosh, on OG Pinephone.
(06-15-2022, 05:05 PM)vgnmnky Wrote: Back when the keyboard came out, there were some hoops to jump through to get access to all of the symbols using, such as £-+, etc.
Same here, can't input any signs from the top row of the physical keyboard, such as "+", "-", "=", etc. in the latest stable release of PostMarketOS.
This patch: https://codeberg.org/HazardChem/PinePhone_Keyboard
seems to be for SXMO UI, but not for Plasma Mobile.
Maybe somebody got this keys to work and can share the magic here in forum?
Thanks!
Update 03.08.2022: Updated from 22.06 to edge. With newer Kernel 5.18 kernel - keyboard is working again. Top Row works with AltG Key.
(07-25-2022, 11:46 AM)explit Wrote: This patch: https://codeberg.org/HazardChem/PinePhone_Keyboard
Thanks!
A permanent fix for Plasma Mobile has been added to `edge`:
https://gitlab.com/postmarketOS/pmaports...uests/3438
Specifically, you need the file `~/.config/kxkbrc` with the content described in the MR. You can also customize the keyboard options fully, with language-layouts and compose key options and other things, like desktop KDE. After adding the file, simply restart Plasma or reboot the phone.
  Bluetooth keyboard paired to PostmarkedOS disconnect Peter Gamma 2 5,817 10-21-2023, 12:32 AM
Last Post: Peter Gamma
  Pinephone Keyboard Utilities on postmarketOS elof 2 7,094 06-20-2022, 01:33 PM
Last Post: elof
  Wifi not working dbrandon 9 18,523 10-09-2020, 06:37 AM
Last Post: quininer
  Working Mailprogram with IMAP pine_sw 6 12,552 10-06-2020, 02:02 AM
Last Post: hiimtye
  Online account (google) not working RodMyers 6 14,435 09-18-2020, 03:58 AM
Last Post: mactoni
Question Virtual keyboard doesn't show the dollar sign ( $ ) vidarr 2 7,207 09-10-2020, 04:27 PM
Last Post: vidarr
Question WiFi looks to be working, but ... vidarr 2 5,784 09-08-2020, 04:21 PM
Last Post: vidarr
  Angelfish on Plasma Mobile not working fernando_c_m 4 10,506 09-06-2020, 10:31 PM
Last Post: bcnaz
  pmbootstrap build large keyboard not usable u20200719 5 12,196 07-25-2020, 02:31 PM
Last Post: u20200719
