Arch Linux ARM root filesystem
#21
(09-12-2021, 10:14 AM)linuxad Wrote: No issues here. Is it possible time is configured incorrectly on your system?
That is also what I thought, but it seems not. I might have to reinstall, I hadn't updated in awhile.
Sorry to use this forum as a bug traker…
Updating my arch-pinebook pro to linux-manjaro.5.18-whatever breaks my hdmi-usb-c output. Downgrading to linux-manjaro.5.17.9-2 fixes it. I dont know if manjaro users have the same issue.
Thanks for your work, once again.
Alex
(06-01-2022, 08:15 AM)alexandre Wrote: Sorry to use this forum as a bug traker…
Alex
Manjaro ARM users have the same issue. Therefore, the root cause is not Arch Linux ARM for Pinebook Pro.
Related merge request that removes USB-C alt display mode for Pinebook Pro from the Manjaro ARM kernel. A closed issue about this. It was removed on account of it being buggy (which it is). I do not see this being fixed in the near future for Manjaro ARM's main kernel.
When I have time I will test and possibly provide Megous' custom kernel, which has several patches specifically for the Pinebook Pro.
Compiled branch 6.0 and 5.19 of the megous kernel for the Pinebook Pro. Both failed to boot, or either seem to boot without anything showing up on the main display.
I will not spend further time on the video output issue until new and stable developments have been made upstream or elsewhere.
My advice is to discuss the lack of USB C DP alt mode support with PINE64 and the Manjaro ARM community.
Ok, fair enough. I keep on downgrading so far and it doesnot seem to break other stuff…
Once again, thanks for your work and time !
Alex
  Can’t login to Linux fnosai 0 3,001 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,055 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,342 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 3,737 06-05-2024, 04:30 PM
Last Post: vxzero
  By the way, yay arch... KC9UDX 4 5,642 03-30-2024, 10:27 PM
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 6,947 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 3,183 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 271,067 05-03-2023, 06:10 AM
Last Post: dachalife
  Encrypted Root jaredoconnor 1 2,927 01-19-2023, 02:27 PM
Last Post: Cs137
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 3,724 11-28-2022, 05:03 PM
