R U running from eMMC -- If so how?
(02-21-2022, 08:43 AM)thechillhacker Wrote: On my PPP I was finally able to get the WIP4 tow-boot SPI installer to boot by holding down the reset switch and spamming volume down while booting, but when I tell it to install, it fails with:
Error: /dev/mtdblock0 not found
and
spi-nor spi0.0:
unrecognized JEDEC id bytes ff ff ff ff ff ff
spi-nor: probe of spi0.0 failed with -2
Has anyone else seen anything like this? For reference, this is from the first january batch of explorer editions. I would suspect a differing SPI flash chip perhaps due to chip shortages, but the "all ff's" tell me it's probably more likely related to the nasty reset thing I had to do to get it to boot in the first place. Has anyone else had similar issues trying to boot the spi installer, or using it?
Oddly enough, WIP3 installs.. odd... Maybe I can now install WIP4. Will update.
Confirmed. If you have the above errors with WIP4, try doing the following:
With WIP3 loaded SD card in the phone, reinstall battery and hold the reset and volume down buttons while powering up the phone. hold these until you see the Tow-Boot installer. Install WIP3. Then do the same thing with the WIP4 installer, without messing with the reset button.
Now to enjoy the full speed of my PPP, and with the SD card being a home or ext. data partition, as it should be!
I installed the WIP4 without any problems , I think you held up the RE buttons for too long and the emmc was completely disabled thus making tow-boot install impossible
Tow Boot should not depend on eMMC presence, but it looks like RE button also disables SPI along with eMMC leaving SD as the only boot option. This makes sense as otherwise there would be no way to recover from a corrupted SPI loader as SPI has the highest boot priority.
I've used Tow Boot to export eMMC and write mobian image to it. Running fine for the last two weeks.
(02-17-2022, 03:31 PM)lllsondowlll Wrote: Step 1. Install Tow-boot from sdcard
Step 2. Hold volume up while powering on to mount the eMMC over usb (Basically jumpdrive for Pinephone Pro)
Step 3. Install Manjaro by writing the image to the eMMC via mounted storage from my computer.
Step 4. I use my unofficial battery case to make the Pinephone Pro last all day with suspend disabled. I can make and receive calls, SMS, and MMS, all are all working. Daily drivable.
Wait! Say what? 1) I've got no idea what "tow-boot" is, 2) is this in lieu of the "mythical' "RE" switch that these consumer alphas have (though mine lacks one), how exactly is that supposed to "work"? 3) now THAT I would LOVE to do! (Did I mention that the command line is DEAD because I have NO keyboard access?) 4) That just sounds FUN!
 Like computing && Like Linux == good people
1) https://tow-boot.org/devices/pine64-pinephonePro.html
2) No - it's part of tow-boot that provides similar functionality to JumpDrive on the non-Pro PinePhone. See the bottom of the tow-boot link above.
(04-25-2022, 04:01 AM)wibble Wrote: 1) https://tow-boot.org/devices/pine64-pinephonePro.html
What is JumpDrive?
What is JumpDrive?
A commonly used uSD image for the original PinePhone (plus a few others) that exposes the eMMC as a USB drive. It hasn't been ported to the PinePhone Pro, but some people mistakenly tried to use it with the Pro.
https://wiki.pine64.org/index.php/PinePh..._JumpDrive
https://github.com/dreemurrs-embedded/Jumpdrive
What is JumpDrive?
Thanks for the information.
Like others here, I used an sdcard to install tow-boot, then reflashed it with the Mobian installer, which has an option to install to eMMC. Worked great! Doing distro-hopping without an sdcard is going to be nearly impossible but best phrased as impractical. A 128GB sd is like $18 on Amazon. Your computer will need an sd card reader, and if you're using Windows and not linux, use something like Rufus for flashing.
(06-07-2022, 06:12 AM)98cwitr Wrote: Like others here, I used an sdcard to install tow-boot, then reflashed it with the Mobian installer, which has an option to install to eMMC. Worked great! Doing distro-hopping without an sdcard is going to be nearly impossible but best phrased as impractical. A 128GB sd is like $18 on Amazon. Your computer will need an sd card reader, and if you're using Windows and not linux, use something like Rufus for flashing.
I would ABSOLUTELY LOVE to do that. Sadly, I have the "no internet blues". Do you happen to have a link to download Manjaro Plasma for the PinePhone Pro? If I can find a site I will download and checksum it. I forgot which Manjaro I have, but something is making me "think" 4.6.?
(02-17-2022, 11:38 PM)lllsondowlll Wrote: Precompiled SPI installer can be found here
https://github.com/Tow-Boot/Tow-Boot/pull/67
Download the WIP4 image for PInephone Pro, extract it, flash the SPI installer image to your SD card, hold volume down when powering on the phone, click install.
No need to use a WIP version, Tow-Boot has an official release: https://github.com/Tow-Boot/Tow-Boot/releases.
Edit: I managed to miss that your post date was before it was released.
  A way to view or log the splash screen on Pinephone Pro running ArchLinux (Danctnix) PHLEMON 4 6,316 07-30-2024, 11:03 PM
Last Post: PHLEMON
Question The Case of the Vanishing EMMC DieSkaarj 9 10,691 07-28-2024, 04:19 PM
Last Post: dchang0
  Mobian + tow boot + emmc flash = boot loop spropine 4 7,807 12-31-2022, 09:14 AM
Last Post: mburns
  How reflash my eMMC? IHaveALinuxPhone 2 4,583 12-01-2022, 05:39 PM
Last Post: IHaveALinuxPhone
  RK3399S running warm LPIZ 8 11,003 05-15-2022, 03:49 PM
Last Post: henrythemouse
  Not Bypassing the eMMC meansbs 3 5,965 04-02-2022, 06:25 AM
Last Post: fxc
  Re-flash the emmc For_lack_of_a_better_name 5 7,698 03-31-2022, 08:31 AM
Last Post: ragreenburg
  Please help! Can't install Mobian to eMMC Barugon 4 6,424 03-01-2022, 06:42 PM
Last Post: Barugon
  PPP Explorer Edition - Wipe eMMC The3DmaN 7 13,077 02-01-2022, 04:34 AM
Last Post: dukla2000
  Erasing the eMMC | Pinephone Pro Vermi 4 10,856 01-26-2022, 01:46 PM
