Keyboard Case Power Management Daemon
Hi, I've made an attempt at writing the daemon Megi described in his blog post about the keyboard case. It's gone well enough that I thought it was time to share.
https://github.com/estokes/pinephone-kbpwrd
The focus is on maximizing efficiency by avoiding moving charge into the main battery where possible. I'm open to discussion, and especially feedback and data.
That's pretty cool.
Quote:At the moment it is only working on the pinephone pro, mainly because that is it's development platform, but also because the PPP has more need of it due to it's higher power consumption. I do plan to make it work on the pinephone at some point.
Please do.
Quote:Because this software runs as root, you should read it, or have someone you trust read it before running it. I know there have been malware incidents in the pine community recently. This isn't malware, but don't take my word for it!
Also very cool.
Oh very cool indeed! I need to build and try this... could be running it in a screen session for now.
I just released a new version that supports the original pinephone as well as the pro. Running i in a screen session is a great idea. Once I get more experience and data I'll write some systemd units so it can start automatically on startup
I was going to thank you for sharing this, but there is actually no LICENSE/COPYING file in the repo. Wink
Cheers,
TRS-80
Protocols, not Platforms
It's MIT licensed, I'll update it.
I'm trying to run this but I get the error
[ERROR kbpwrd] error: Invalid cross-device link (os error 18) will retry
Also here is a simple systemd script that could start it
kbpwrd.service
[Unit]
Description=Pinephone (Pro) Keyboard power management daemon
[Service]
Type=simple
ExecStart=/usr/bin/kbpwrd
[Install]
WantedBy=sysinit.target
I have seen that error a few times when the pogo pins weren't making good contact, so perhaps that is the issue. The daemon just reads sysfs files, so you can easily check if you have the same problem when you read them manually.
an easy one to try is '/sys/class/power_supply/battery/capacity'
(02-18-2022, 02:40 PM)estokes Wrote: Hi, I've made an attempt at writing the daemon Megi described in his blog post about the keyboard case. It's gone well enough that I thought it was time to share.
Megi is integrating this functionality into the kernel (where it honestly belongs IMHO). As such my project is deprecated.
https://xnux.eu/log/#065
Your contribution to the PinePhone project is much appreciated! Smile
Though personally I've had no luck getting the Keyboard case working on the PPP, although it works fine on my original PP, I've tried the suggested trick of pushing the pins on the case slightly close to the pogo pins on the phone, but that has made no difference, I cant use either the keyboard functionality or the battery charging functionality.
  Battery Management on PinePhonePro: d50zesl0g@mozmail.com 4 4,622 03-02-2025, 11:52 AM
Last Post: d50zesl0g@mozmail.com
  Battery meter slowly reducing under keyboard charger robocone 1 3,502 12-26-2022, 09:37 AM
Last Post: robocone
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 10,013 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Fix keyboard layout robocone 1 4,229 05-16-2022, 08:03 AM
Last Post: robocone
  Screen keyboard Japanese input issue Yst 1 3,168 04-30-2022, 09:13 PM
Last Post: TRS-80
  PackageKit daemon has crashed dgiffin 10 17,711 03-22-2022, 05:02 PM
Last Post: S H
  Howto Full disk encryption manjaro and detached header (with keyboard) robocone 0 4,261 03-09-2022, 06:53 AM
Last Post: robocone
  Keyboard stopped working -- big problem tckosvic 15 18,071 02-06-2022, 02:04 PM
Last Post: Emilio
