USB3.0 Issues at DietPi(Armbian) #22.02.1
Refer spiritofjerry's post : https://forum.pine64.org/showthread.php?tid=6187&page=6
Environment actually i tried.
# DietPi
# https://dietpi.com/downloads/images/Diet...ullseye.7z
# uname -a
Linux rock64 5.15.25-rockchip64 #22.02.1 SMP PREEMPT Sun Feb 27 09:05:47 UTC 2022 aarch64 GNU/Linux
reference: kerrnel-set (at least usb3.0 issuses exist)
# https://armbian.site-meganet.com/apt/poo..._arm64.deb
Problem improvement.
# gzip -d -k rk3328-rock64.dtb.gz
# mv -v /boot/dtb-5.15.25-rockchip64/rockchip/rk3328-rock64.dtb /boot/dtb-5.15.25-rockchip64/rockchip/rk3328-rock64.dtb_
# cp -v rk3328-rock64.dtb /boot/dtb-5.15.25-rockchip64/rockchip/
# reboot
There are a huge number of usb devices on the market, and there are always compatibility issues,
so I don't think all the issues will be solved.
However, I improved it so that it works properly with my USB device. (USB3.0-HDD etc.)
As mentioned above, the process is as simple as replacing a single file.
If you are encountering problems, please give it a try.
# sha1sum: 31ac801a4c0ae5e87745eb638f8c663d02b89dbd    rk3328-rock64.dtb.gz
.gz   rk3328-rock64.dtb.gz (Size: 12.53 KB / Downloads: 575)
Great T4_4t,
OMV was not recognized HDD connected to USB3 but after this patch, it's working again.
Thanks.
Many thanks for this. I had to make a few alterations to the script to reflect the file name on my Rock64 but it worked like a charm. My file server is now performing as it should.
Thanks again.
@t4_4t,
Please consider submitting this patch to Armbian!
Cheers,
TRS-80
Protocols, not Platforms
  DietPi OS for ROCK64 MichaIng 43 97,270 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 - not booting after Armbian update helpmerock 7 7,598 01-24-2026, 04:44 PM
Last Post: ff255
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 3,361 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Armbian for Rock64 pineadmin 57 134,746 04-01-2022, 03:16 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 2,560 02-28-2022, 05:06 PM
Last Post: TRS-80
  Armbian/Ubuntu for Rockbox Wizzard 5 9,731 05-18-2021, 08:18 AM
Last Post: Wizzard
  Armbian 5.4.43: Network is unreachable; Red LED blinking; RNG failure? aves 1 5,558 07-27-2020, 02:04 PM
Last Post: aves
  Unable to boot armbian fchazal 2 7,062 05-19-2020, 06:43 PM
Last Post: Rocklobster
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 5,559 03-31-2020, 07:19 PM
  csdr build issues. TravisH 0 3,550 02-19-2020, 04:47 AM
Last Post: TravisH
