GAPPS (Waydroid) on the Pinephone Pro
So I got waydroid (sort of) working on my phone. I installed the GAPPS image, but Play Protect won't even let me install apps through the play store. Not a big deal if you use outside images, but I am assuming that the app I want specifically (Google Voice) is going to need GAPPS functioning. Any ideas?
Normally you'd need to register your Google Services Framework Android ID at https://www.google.com/android/uncertified/?pli=1 like you would for a typical custom rom that isn't certified. But as far as I can tell the waydroid image doesn't actually have an ID. At least in the Arch version its not shown in the menus and the adb commands don't run properly. If you figure out a way to extract the GSF ID I'd be interested to know.
(03-30-2022, 07:33 PM)brb78 Wrote: Normally you'd need to register your Google Services Framework Android ID at https://www.google.com/android/uncertified/?pli=1 like you would for a typical custom rom that isn't certified. But as far as I can tell the waydroid image doesn't actually have an ID. At least in the Arch version its not shown in the menus and the adb commands don't run properly. If you figure out a way to extract the GSF ID I'd be interested to know.
I'll see what I can figure out.
I have used Device ID or ( ANDROID_RUNTIME_ROOT=/apex/com.android.runtime sqlite3 /data/data/com.google.android.gsf/databases/gservices.db "select * from main where name = \"android_id\";" ) from sudo waydroid shell . Though upon registering it doesn't activate on the device. The GSF ID also resets on container reboot.
This has been my experience with this though.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 21,310 10-20-2025, 07:01 AM
  Bare metal on Pinephone Pro alain 0 3,495 08-19-2025, 07:58 AM
Last Post: alain
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 4 7,654 08-19-2025, 01:38 AM
Last Post: geometrylitegame12
Star FreeBSD developer build for PinePhone Pro teekay 1 2,676 05-03-2025, 11:02 AM
  freeBSD is booted on pinephone pro with console output zetabeta 5 5,522 04-18-2025, 12:56 AM
Last Post: teekay
  How to Clone Kali Linux to PinePhone Pro with Terabyte IFW TOF 2 5,672 02-26-2025, 02:15 AM
Last Post: TOF
  Anyone gotten latest Ubuntu Touch to work on PinePhone Pro? dchang0 4 8,901 12-22-2024, 04:21 PM
Last Post: dchang0
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,089 10-28-2024, 10:46 AM
Last Post: Jite
  tow-boot, just bought pinephone pro stratofall 4 4,823 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 101,244 02-13-2024, 02:54 PM
Last Post: fxc
